Thread: '02 A3 1.6 stuttering at 55-60mph
  1. '02 A3 1.6 stuttering at 55-60mph
    Jun 2008
    Hey there, help please !
    My A3 is stuttering at cruising speed. It's ok on and off the throttle, just when revs are constant. I replaced split intake and breather hoses. It was serviced 6k ago, air filter and plugs look ok, used a bit of oil, never did so before.
    I suspect a dirty MAF sensor, engine seem to be running hotter but temp gauge is normal. Uses more fuel than before. Don't have a VAG reader so haven't got it plugged in yet but trying to do all simple things before i open my empty wallet.
    Anybody got any ideas? Dealers are useless in ireland...
  2. Re: '02 A3 1.6 stuttering at 55-60mph
    Jun 2008
    Wolverhampton
    I had something similar on my 2001 Octavia 1.6 (which may have the same engine as yours). I had the engine electronics light go on which indicated a HT lead failure in cylinder 2 when my mechanic interroageted it with VAG-COM. It may be that yours is similar.
  3. Re: '02 A3 1.6 stuttering at 55-60mph
    Jun 2008
    Thanks for the help folks.... sorted now, new bosch plugs, cleaned and resistance checked leads, removed and cleaned MAF sensor....
  1. Rumbling between 30-60mph
    By d_onions in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2012, 09:29 AM
  2. A4 lacks power over 60mph.
    By ian12345 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-12-2010, 11:12 PM
  3. engine cut out at 60mph!!!!!!!!!
    By hornetcarp in forum Golf MK3 - 1993 - 1999
    Last Post: 09-03-2008, 09:38 PM
  4. 6th gear OK at 60mph? Golf 2.0 gt tdi
    By architect in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2008, 12:00 AM
  5. Limp mode @60mph !
    By Passat2003 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2007, 10:46 PM
