Thread: mk2 gti driveshaft HELP!please
Results 1 to 10 of 15
  1. Exclamation mk2 gti driveshaft HELP!please
    Dec 2007
    hi i have a mk2 golf gti which i have shapped the driveshaft in two i am looking for another driveshaft secondhand will a 1.8 golf driver fit as i have seen one on e bay i am really not sure or if any one has one i can buy send me a price
    thanks
    craig
  2. Re: mk2 gti driveshaft HELP!please
    Aug 2008
    think i have 2 shafts lying about if i get a min il have a look where are you from??
  3. Re: mk2 gti driveshaft HELP!please
    Dec 2007
    hi that would be grate thanks
  4. Re: mk2 gti driveshaft HELP!please
    134 Post(s)
    2005 Post(s)
    A 1.6 Driver has 90-mm inner CV’s and a 1.8 100-mm inner CV’s so there should be no problem with the fleaBay one.
  5. Re: mk2 gti driveshaft HELP!please
    Dec 2007
    cheers hopin to have 1 this weekend
  6. Re: mk2 gti driveshaft HELP!please
    anyone of you got a spare outer cv joint left,a mate of mine needs the inner bearing holder and the plastic washer,if so can you email me on clayhea@yahoo.co.uk,cheers
  7. Re: mk2 gti driveshaft HELP!please
    134 Post(s)
    2005 Post(s)
    The plastic thrust ring as it is known is VW part number 321 407 295 A and costs 29p. If by the inner bearing holder you mean the cage then they are not easily swapped, it is almost impossible to rebuild a CV as the 6 balls, 6 inner surfaces, 6 centre surfaces and 6 outer surfaces tend to form a bind boggling number of permutations, someone good at maths will be able to tell you how many.
  8. Re: mk2 gti driveshaft HELP!please
    im lost mate ive got 4 of them here and iv stripped all of them down and rebuilt them and theyve all gone back together,did you mean theyl go back together but not correct??cheers 4 the part number by the way ill pass it on
  9. Re: mk2 gti driveshaft HELP!please
    134 Post(s)
    2005 Post(s)
    You are obviously better than me then.
  10. Re: mk2 gti driveshaft HELP!please
    i doubt that dude,alls i did was push one side of the bearing holder in and the middle bit too so the bearing was sticking out,then pop the ball beaing out of the holder,repeat this for all 6 then turn the holder 90 degrees and rock it out,then do the same fot the middle bit,ill try do some pics if that helps
  1. Please Help Inner RH Driveshaft Boot
    By Jellyvelcro in forum Early Passat Forum - Pre 97
    Last Post: 19-08-2008, 10:09 AM
  2. Driveshaft / wheelbearing help
    By cuffbert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-01-2008, 11:54 PM
  3. Can't find A6 4.2 V8 driveshaft - help!
    By Daveymaclad in forum Archive posts
    Last Post: 18-10-2007, 02:06 PM
  4. VW Passat tdi 130 Driveshaft
    By Jetlag001 in forum Passat - Archive Topics
    Last Post: 22-07-2007, 01:45 PM
  5. VR6 Driveshaft...
    By mitchcar01 in forum Archive posts
    Last Post: 18-04-2007, 06:43 PM
