Thread: Passat 1.8 20v Turbo 1998, ignition problems
  1. Passat 1.8 20v Turbo 1998, ignition problems
    Nov 2008
    Ok its hunting on idle and loss of power.
    1: Changed all 4 spark plugs.
    2: Put on Vag com no codes.
    3: Had compression test done and ok.
    4: Full service.
    5: New coolant sensor.
    If i take off coil plug No. 2 it makes no difference, but if i unplug 1,3 or 4 it does so i suspected coil pack 2, changed it in local parts shop but did nothing so took it back for refund after they swapped it twice as it didnt improve.
    So i unplugged all 4 plugs that go into coils (3 pin connectors) got me multi meter on em and pins 1 & 2 voltage of 14.2 volts on all 4, so went on and tested pin 3 in all 4 plugs for voltage and 1,3 & 4 showed voltage of about 0.53 and plug 2 was 0.00....?
    So does this prove that plug/lead 2 is at fault or is there else where i should be looking....?
  2. Re: Passat 1.8 20v Turbo 1998, ignition problems
    Jan 2009
    towcester northants
    check tci pack on the top of air cleaner this gives same fault
  3. Re: Passat 1.8 20v Turbo 1998, ignition problems
    Nov 2008
    So you suggest it could be the Ignition Control Module that sits on top of air filter box, it has 2 leads 1 either side... Do the 2 leads split in to 2 to feed the 4 coils...?
    So its either one of the leads as no. 2 has no spark or its the control module then...?
    Why hasnt Vagcom picked up this problem...?
  1. ABS control module 1998 VW Passat GLS 1.8L turbo
    By adrian537 in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 11:02 PM
  2. 1998 Passat B5 20v Turbo Query
    By kjshares in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-05-2007, 09:26 PM
  3. Alarm Problems - 1998 Passat 1.9TDI
    By Col in forum Passat - Archive Topics
    Last Post: 12-02-2007, 02:30 PM
