Thread: Rear Brakes Siezed
  1. Rear Brakes Siezed
    May 2008
    I have been trying to swap the rear pads and discs, and have now tracked down the source of my frustration to siezed slider pins.
    The upper slider pin on both sides is totally seized in the caliper bracket.
    As both sides are exactly the same, I am guessing this is a common problem.
    Is there a well known fix for this? or failing that is there somewhere well known that I can buy replacement caliper brackets and pins?
  2. Re: Rear Brakes Siezed
    Jul 2008
    stoke on trent
    had the same problem with one of mine, little rubber boot split allowing water in and it rusted solid, managed to free it with a big hammer and plenty of wd-40
    then removed rust with wire wool added plenty of grease and a new boot
    works fine now!
  3. Re: Rear Brakes Siezed
    May 2008
    OK, wire wool not now an option - one slider pin sheared off. one bracket can only be removed from the car with a grinder.
    I guess the local Audi dealer is now going to fleece me for a few hundred for a couple of brackets, pins and countless 'use once' bolts
  4. Re: Rear Brakes Siezed
    Jul 2008
    New Zealand
    Quote Originally Posted by Smo View Post
    Check eBay. I know it''s a cliche, but there are cheap parts to be had.
    1997 Audi A4 TDi Quattro Avant
  5. Re: Rear Brakes Siezed
    mine were seized as well,i managed to get one out but i managed to bend it slightly,i managed to get it straightish but i need new pins which you cannot buy seperatly.my slider boots are in good condition.
  1. rear brakes abs
    By dackworth in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2009, 11:08 PM
  2. Rear Brakes
    By Matt01 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2008, 04:54 PM
  3. Upper hub bolt - siezed?
    By vwmark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2008, 05:59 AM
  4. Rear brakes
    By britaxcooper in forum Golf MK3 - 1993 - 1999
    Last Post: 26-12-2007, 11:13 AM
  5. Audi A4 - Siezed sump plug
    By A4Chris in forum Archive posts
    Last Post: 10-05-2007, 10:37 AM
