Thread: A4 Avant Rear shock Change - How do I remove the boot trim to get to the strut mount?!?!
  1. Question A4 Avant Rear shock Change - How do I remove the boot trim to get to the strut mount?!?!
    Searched through the forum and can't find any old threads, so here goes:
    Doing damper change on my 1999 b5. Haynes does not explain how to remove the trim to get to the strut mount to remove bolts (it just says remove carefully!!). I've removed the boot floor/flap, I've removed the boot 'sill'. I am working on the off side panel and have managed to free most of the trim card upto the seat lock pin. I've loosened the pin but do nt want to remove for fear of the nut fropping into the body work.
    How do I remove the trim card? WHat am I missing??
    Any help appreciated.
  2. Re: A4 Avant Rear shock Change - How do I remove the boot trim to get to the strut mount?!?!
    Jul 2008
    stoke on trent
    seat lock pins screw into captive nuts so they wont fall down. trim panels clip in but 'remove carefully' is good advice, i think i broke half the mounts the clips are mounted in when i removed mine
    if i remember correctly there are a few screws aswell where shelf clips in but no hidden ones
  1. How do I remove the Passat Estate boot trim?
    By robroy959 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-03-2013, 03:06 PM
  2. Golf mk 3 rear left engine mount change
    By spainy in forum Golf MK3 - 1993 - 1999
    Last Post: 11-05-2008, 04:11 PM
  3. 4motion estate rear shock change ?
    By 5portsrock in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-04-2008, 09:31 PM
  4. Front strut mount failure
    By dave.1983 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-04-2007, 12:19 AM
  5. Audi 80 Shock Absorber Mount
    By KRed in forum 80 - 90
    Last Post: 20-12-2006, 05:39 PM
