Thread: ECON button
  1. ECON button
    Apr 2007
    Bedfordshire
    The econ button is perminently illuminated on my heater control panel and I can`t switch it off thus my aircon is not working. Can anyone help ?
    Steve
    A4 Avant 2.0 Petrol 53 plate
  2. Re: ECON button
    Feb 2004
    Yorkshire
    46 Post(s)
    Have you tried pressing the "auto" button? Although I have not used it in my Seat for a while, If I remember correct I have to press the "auto" button to switch the AC back on...
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of BMW Car Club GB
    Ways to support the website
  3. Re: ECON button
    Apr 2007
    Bedfordshire
    Stuart,
    I have tried as you suggested but even with the auto switched on the econ light is still there
    Steve
  4. Re: ECON button
    Feb 2004
    Yorkshire
    46 Post(s)
    When was the last time the system was serviced? it may be low on gas, which will make it stay off to protect the system..
    A service and regas should cost aroun £50'ish
  5. Re: ECON button
    Aug 2007
    Cumbria
    Mine was doing that. I got a new high pressure sensor (about £50) as they fail and that is a common reason for the econ light staying on.
    However, I also got the system checked and re-gassed and now it's fine. I'll try and get a refund on the unused part!
    It's interesting as the garage computer gave a High Pressure Sensor fault but apparently this message can be either due to a faulty sensor or (as in my case) low refrigerant levels.
    53 1.9 TDi 130 SE [6] Avant Ocean Blue
  6. Re: ECON button
    Apr 2007
    Bedfordshire
    Thanks I will get the system checked
    Steve
  7. Re: ECON button
    Quote Originally Posted by noshock65 View Post
    Steve
    You can buy air con regas kits from halfords for about £40.
    Its very easy to do.
    The kit comes with a pressure gauge that will tell you if you need to fill the gas.
    I also had this issue on my car due to low gas. Once I filled it up it was fine again.
    Amit
  1. ECON Button???
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2010, 07:55 PM
  2. Please Help A4 Cab 'Econ' button stays on whilst using Climate Control
    By mrug35 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-07-2008, 12:12 AM
  3. Replies: 0
    Last Post: 02-11-2007, 05:36 PM
  4. 2 button and 3 button fobs / remotes
    By Loofer in forum Archive posts
    Last Post: 07-08-2007, 02:08 PM
  5. A4 Econ Heater Button Stuck On
    By Colin Preece in forum Archive posts
    Last Post: 09-03-2007, 08:53 PM
