Thread: Cant find switch ignition...no 75x
  1. Re: Cant find switch ignition...no 75x
    Jun 2008
    Hi
    I metered the three spares and a few shared fuses but all were live. Must I tap into a shared fuse, prefer to splice a wire if no other options left.
    Took a few pictures of the area under my drivers side area to show what I have. Sorry about the poor quality but was taken at night with my mobile phone without flash plus a torch. The unmarked 3 posts on the bar bus are all live.
    Can I ask on the A4 does one need to wait for xx time before a live ignition goes "off"? Reason I ask is because I metered the cigarette socket and thats live even after ignition is off?
    J
    Quote Originally Posted by Issac Hunt View Post
    My B6 had a 75x terminal, if you havent got one or cannot find it, why not just tap into an ignition live from the fusebox?
  2. Re: Cant find switch ignition...no 75x
    May 2008
    The Cig lighter is always live. My B6 def had a 75x terminal as thats where I fitted my road angel to. However my B7 doesnt have one so when I fitted my road angel to this car I just tapped into an ignition live feed from the rear of the fusebox. I used the reverse light fuse and have had no problems in over a year of usage.
    As long as what ever you intend to power doesnt draw a huge current you should have no problems. If it does draw a large current then of course it will be better to wire in a relay to power it. The road angel I have draws very little current so its no problem for me.
  3. Re: Cant find switch ignition...no 75x
    Jun 2008
    No 75x for sure as I looked everywhere under the drivers side area.
    I will take your advise and use the reverse light for my radar install.
    Thanks again
    J
  4. Re: Cant find switch ignition...no 75x
    Jun 2008
    Noticed that the reverse light shares the same fuse with the multitronic gearbox which is something I prefer to leave alone. Took the switched ignition from the 5A headlight leveling system which is a standalone fuse, works a treat.
    Thanks for the tip
    J
  1. Question ignition switch
    By boru in forum Golf MK3 - 1993 - 1999
    Last Post: 21-05-2008, 05:25 PM
  2. Audi 80 Ignition switch
    By zkav8or in forum 80 - 90
    Last Post: 22-02-2008, 05:26 PM
  3. Dreaded ignition switch
    By joebrown9 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-01-2008, 09:55 PM
  4. Can't find it - the switch for my internal lights that is.
    By Dora the Bora in forum Bora - 1998 - 2005
    Last Post: 28-10-2007, 11:09 PM
  5. MK3 Ignition Switch trouble?
    By milescook in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2007, 04:18 PM
