Thread: Digi display in center of dash Fault
Results 1 to 10 of 14
  1. Digi display in center of dash Fault
    Aug 2008
    Hi i have a 2000 1.8t quattro sport avant. The digital display has broken lines in the vertical and horizontal. Does this mean an entire replacement dash or can you get a replacement digital display.
  2. Re: Digi display in center of dash Fault
    Were I is Now
    Ahh the old cluster pox :-(
    It's a new intrument panel complete from Audi - there are a few companies starting to offer a repair service, but not many in the UK - if any.....and they need the entire cluster to work on it....
    Not a simple swap over either - as the dash contains the immo...so needs to be coded too....so I can see why there are a few repair companies looking at this very common problem....for about half the dealership cost...
    Last time I asked it was about £450+vat for a swap out unit......
    I've lost just one horizontal line...sometimes....but it falls just a single line below the bottom of the normal display, so when It's out I can only 'see' it on startup/or some warning symbols it cuts through.... seems to be heat/damp related, and sometimes a few cycles of the auto-check will pop the line back up...
    2010 S4 in exclusive classic red and every option under the sun...as well as my 80 cabriolet 2.6e auto fun day car...not forgetting a slightly Smashed but saved waiting for some repairs 01.5 B5 A4 2.4SE Tip - Votex body kit, Hidden Microwave PDC, Pirelli X-Pressure TPMS, Hardwired Bel RX65e, Lamp Guards...and the exclusive Red Logo Audi Sport Valve Stem Caps!
  3. Re: Digi display in center of dash Fault
    Aug 2008
    Thanks for your help i think i will live with it for now at least.
  4. Re: Digi display in center of dash Fault
    Southern County Softy
    20 Post(s)
    Repairs available here
    http://www.bba-reman.com/
    A4 2.5 tdi QS (mapped)
  5. Re: Digi display in center of dash Fault
    Were I is Now
    Quote Originally Posted by kite View Post
    That would be the one i was thinking of....but I've not found anyone who's had one done - here in the UK or the US...where I think I first saw mention...
    Price is not too bad compared to dealer replacement I guess
  6. Re: Digi display in center of dash Fault
    Somewhere on the A1 between Edinburgh and Leeds
    Yeah my 00 V is doing it too. It comes and goes but at its worse I have had about 3 horizontal AND 3 vertical lines out so makes making out MPG etc fun if it clips a line I don't know if it is a 3 or an 8! Doh!
  7. Re: Digi display in center of dash Fault
    Nov 2006
    Oldham, Manchester, UK
    I've just got myself a 98 A4 although mine is a bit more severe (or not)
    I noticed when I got the car that there were some lines in the display although its gone off altogether now, hopefully just a bulb????
    '96 A4 1.8. For spares now
    '98 A4.........New headache
  8. Re: Digi display in center of dash Fault
    Won't be a bulb as it is using LED technology so it is actually the led lines shutting down for whatever reason. There is no bulb as part of this bit of the display.
    Quote Originally Posted by Marc97 View Post
  9. Re: Digi display in center of dash Fault
    Were I is Now
    If it's all out - could be turned off - the reset switch on the stalk - brief click is on/off. Even when off you can still see the lines that will be out when on in most cases...sounds like what you had, so my money is on the on/off here....
  10. Re: Digi display in center of dash Fault
    Mar 2008
    Hi, I have a similar problem with the cetre display but the whole display slowly fades away. It's perfect at start-up with no characters missing but slowly fades and becomes unreadable. Sounds like the same problem and as someone has already said could be heat related? Any comments
  1. center console fault
    By S3 beast in forum Audi A3 - Archive Topics
    Last Post: 26-06-2008, 07:03 PM
  2. Barcode on dash display?
    By kesselrun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 08:17 PM
  3. 1991 V8 quattro dash display icons
    By MattPryce in forum A8 - S8 - V8
    Last Post: 08-04-2007, 12:38 PM
  4. Dash Display
    By parmaham in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 05:50 PM
  5. A4 tdi 03 DIS-Dash display-fault
    By a4ianf in forum Chat - Completely Off Topic
    Last Post: 21-11-2006, 03:26 PM
