Thread: cold start problem on A4 99'
  1. cold start problem on A4 99'
    When I start tha a4 in the morning it wont start, you press the gas pedal while starting it starts but in very very low idle and shaky after it warms up a little it becomes normal and runs good.
    Any halp on my issue wil l be appreciated
    thanks a lot
    wescyj
    Dec 2006
    Kent and Guernsey
    Quote Originally Posted by wescyj View Post
    thanks a lot
    wescyj
    Hi, Sometimes, this problem can be to do with the ECU. Try disconnecting the battery, as this will allow the ECU to reset itself. There are, of course, many other reasons. Good Luck.
  3. umm
    it mite be your automatic choke no kicking in.
  4. automatic choke
    where how can I find the automatic choke?
    Canada
    It would be easier to diagnose if you state the engine you have eg diesel or petrol.
    Rob
  6. engine
    wot engine do ya have in ya 99 a4 lad.??
  7. cold start A4
    The A4 run in gas. I always but 93oct reg gas.
    Barrow in furness
    your runnin gass? as in petrol or lpg? :S if yr running on lpg then you cant start a car on lpg or it is dificult i.e rough running u need to start them on petrol then switch to lpg, but by 93 oct am assuming u mean petrol :S try cleaning out the throttle body
    -----------------------------200BHP 320NM------------------------------------
    Canada
    I agree with rick, it probably your throttle body that needs cleaning. I assume from the gas reply that you are in America.
    93 ron Gas seems a bit low, over here we run 95 ron unleaded or 98 ron super unleaded.
    Do you have a owners manual for the car?
    Hope this helps
    Rob
  1. Cold Start Problem Tdi 110 Golf ???
    By robdcaterham in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2007, 01:55 PM
  2. Cold Start Problem
    By robdcaterham in forum Archive posts
    Last Post: 21-03-2007, 07:24 PM
  3. Cold Start Problem
    By Cam in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 03:33 PM
  4. audi 80 cold start problem
    By chrispey in forum 80 - 90
    Last Post: 25-12-2006, 10:41 PM
  5. 1992 MK3 Golf 1.8 CL - Cold Start Problem
    By drillyourownhole in forum Golf MK3 - 1993 - 1999
    Last Post: 06-03-2006, 03:55 PM
