Thread: Door lights not working
  1. Door lights not working
    Aug 2008
    Hi All
    My problem is that when I open any door of my 1996 A4 the light in the roof does not work. I have set the light switch correctly in the roof and it does not work. However all light in the top are functional. Adding to that when I do take the key out of the car the lights in the roof of the car do light correctly. I even tried replacing the whole light module that is in the top roof but that did not change anything.
    So I do believe that there is some IC or some Fuse that is broke but I just cant seem to find out which one. Can anyone tell me what to do ? It used to work great.
    I was told that it might be a stuck circuit. But without further details that knowledge is useless to me. I know how to dismantle the door fabrik to reach the doors guts. And I know where the door locking mechanism is located. But what then ?
  2. Re: Door lights not working
    Were I is Now
    Door contact switches I'd say....are they the post type on a '96...easy to swap if they are....later ones are built into the door lok iteslf :-(
    Same on all 4 doors?
    2010 S4 in exclusive classic red and every option under the sun...as well as my 80 cabriolet 2.6e auto fun day car...not forgetting a slightly Smashed but saved waiting for some repairs 01.5 B5 A4 2.4SE Tip - Votex body kit, Hidden Microwave PDC, Pirelli X-Pressure TPMS, Hardwired Bel RX65e, Lamp Guards...and the exclusive Red Logo Audi Sport Valve Stem Caps!
  3. Re: Door lights not working
    Aug 2008
    Yes same on all four doors...
  4. Re: Door lights not working
    Were I is Now
    Quote Originally Posted by alinux View Post
    And do you have contact switches you can see or are they part of the lock mechanism (sp)? You might get some more info out of a scan - could be water has got to the control unit...but you would usually see other 'funky' things going on too....
    So what you have is :
    The lights work when you are sat in the car using the dome switch - with and without the key?
    The lights work when you leave the car - ie key out lights come on.
    The lights go out when you lock up the car.
    Your don't get lights on when you open the car....
    Do you have the DIS that shows doors open etc?
    Sounds like more than just a contact switch not working correctly - unless they all run in-line with each other....
  5. Re: Door lights not working
    Nov 2006
    Oldham, Manchester, UK
    Mine has same fault. Unlock the doors, light comes on, start car, light goes off, take the key out of the ignition, light comes on, lock the car, light goes off. The light also goes off after about 15 or so seconds but when I open the door (any door), no light!
    As for the contact switches, if I leave the headlights on and open the door the warning buzzer sounds so the contact switch seems to be working.
    The interior light control is part of the central locking module on mine (95/96 without RCL) and I've fitted several of these due to a central locking fault so I ruled that out. Is there a seperate control unit?
    '96 A4 1.8. For spares now
    '98 A4.........New headache
  1. Reversing lights not working.
    By Mack57 in forum Touran - Sharan - Caravelle
    Last Post: 01-09-2013, 11:42 AM
  2. Door warning lights...not working
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-06-2008, 07:41 PM
  3. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
  4. Puddle Lights and courtesy lights not working
    By PerArdua in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2008, 01:43 PM
  5. Reversing lights not working?
    By sim69bed in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2007, 10:59 PM
