Thread: Help! A3 2.0TDi limp Mode P0299
  1. Help! A3 2.0TDi limp Mode P0299
    Aug 2008
    High Wycombe
    Hi everyone, im a newbie so sorry if I am not posting correctly
    I have a question for all you clever people
    I have a 2004 A3 2.0DSG that keeps going into limp mode with an engine code of p0299, I have done loads of google'ing and people are talking about turbo actuator or N75 valve.
    The story so far....
    Throttle sensor and solenoid block have been changed, vacum tests have also be done and am told that all is good from that...
    I was told that the 2.0tdi does not have a N75, this was replaced by the solenoid block but replacing that didnt work, I cant see and leaks in any air pipes etc. either, the car has been to Audi and they tell me they cant fix it, yes i was in shock to! They did however change a glow plug because they thought that may solve the issue, so I am never going back to Audi
    Has anyone had a similar problem to this before? or does anyone have any suggestios from here, I personally dont think the turbo is at fault because if it was then surely it would be in limp mode all the time or not?
    Another point to add is that it has had an oscarri remap but this was done a long time after the problem first started and it doesnt seem to have made any difference at all
  2. Re: Help! A3 2.0TDi limp Mode P0299
    Quote Originally Posted by kamranj View Post
    Hi,Yes my A3 20 tdi dsg had a simular problem.Dealer had to replace cracked cylinder head and turbo at 30K miles,now I have starting probs.
  3. Re: Help! A3 2.0TDi limp Mode P0299
    Aug 2008
    High Wycombe
    Ouch that must have been expensive!
    After months of running around I finally got this fixed yesterday, turned out to be the manifold flip motor....
    Loads of people have had issues with these, i though vags were meant to be solid....
  4. Re: Help! A3 2.0TDi limp Mode P0299
    Glad you got sorted, it is very annoying / frustrating when can't find problem, sorry to be naive is this "Manifold flip motor" known has anything else.
    i have similar problem on a 1.9tdi 130 (2002) intemittently turbo issue, some times turbo cuts in or don't
    thanks
    Mark
  1. Limp Mode
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-03-2010, 11:45 PM
  2. Limp mode - think I'm going to cry!! lol
    By MikeMc in forum Golf MK4 - 1999 - 2004
    Last Post: 22-04-2009, 09:47 AM
  3. (another) Limp mode TDI
    By EdBe in forum Octavia
    Last Post: 14-06-2008, 02:55 PM
  4. Limp Mode?
    By Izalman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2008, 08:20 AM
  5. Is this limp mode??
    By fasttdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2008, 03:37 AM
