Thread: In car audio question
Results 1 to 10 of 11
  1. In car audio question
    Hi all,
    Not sure whether this would be better in here or general chat.
    I've got the standard 10 speaker set up in my '03 A4 (2 mids + 2 tweeters in the front, same in the back and the 2 subs) and will be putting a Pioneer head unit in there when I get round to taking out of my other car.
    The Pioneer head unit has 2 sets of preouts (Front and Rear or Front and Subs). I was wondering if I would be able to connect the Fronts and the Subs to 2 amps and drive the Rears from the head unit.
    I'm going to be putting component speakers in the front and maybe change the subs too. If I could do this, what kind of amps would I need (I know 2 channel for the Fronts but do I need a 4 channel bridged for the subs) ? Would I be able to use one amp that would drive the Fronts and the Subs ?
    Cheers,
    Richie.
    Kent
    Hi Richie
    How you have suggested (front,subs and head unit for the rears) is probably the best way to go, you could use 2x 2 channel amps and wire the subs in either series or parallel this is assuming you are using single voice coil subs, if you are going to use Dual Voice coil let us know nd I will dig you out the diagrams for those, if you wire in series your amp must be stable at 2 ohm where as in parallel this isn't so important alternatively you could use a 4 channel and wire up in much the same way but again be careful what amp you use most American amps (Kicker, Rockford, Phoenix Gold etc) are usuallly stable to 2 ohm some Jap ones (Pioneer, Kenwood ETC) may not be. I have attached the wiring diagrams for your subs.
    Let us know how you get on or if you need any more info
    Eclipse car Audio
    Kent
    Only 1 file attached for some reason this is the Parallel one
    Jul 2006
    outer space
    I was wondering, if your taking out your Audi radio, what sort is it and do you fancy selling it to me the FM receiver is bust on mine,
    Kent
    Whats wrong with your FM as it may be the Aerial Amp and not the radio itself
    Jul 2006
    outer space
    Ahh.....on FM it crap, for example in my van i pick up Radio1 anywere, in the car i can only get around towns.
    Kent
    It could well be the amp one easy way of testing is to remove the radio and unplug the aerial now get a test light (pointy screwdriver with croc clip on the other end) poke the pointy end into the aerial socket on radio and dangle the croc clip out of the window or hold up in the air now try tuning the radio (unfortunately about 4 hands for this) if you pick up more stations this way then I would say that the amp has gone. What year is the car?
    Jul 2006
    outer space
    Hi - its 03, i took it down to my local Radio guy, he removed the radio and checked the arial connectionon the back and said "thats fine your fm receiver is bust" so i just thought "f" it i will live with it, on my motor the arial seems to be in the rear windscreen, so weres the amp?
    Kent
    The receiver is located at the top of the rear window under a plastic trim PM me your email address and i'll send you a picture
    Jul 2006
    outer space
    Ok pm'd you,
    Thanks for the help, i reckon its that as well.
  1. Audi Audio Questions
    By 8520jason in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2008, 11:45 PM
  2. Audio upgrade?
    By AUDICAB99 in forum 80 - 90
    Last Post: 29-05-2007, 11:15 PM
  3. Golf audio upgrade
    By Paul_mkV_golf in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-05-2007, 05:24 PM
  4. Monsoon Audio system?
    By carl s in forum Passat - Archive Topics
    Last Post: 31-03-2007, 07:09 PM
  5. A4 Audio problem?
    By DaveG in forum Archive posts
    Last Post: 08-11-2006, 10:46 AM
