Thread: flashing coil light
Results 1 to 9 of 9
  1. flashing coil light
    nottinghamshire
    is this an engine warning light ?
    does anyone know what fault it maybe?
    thanks
  2. Re: flashing coil light
    7 Post(s)
    It is indeed a fault.
    You really need to get it read for faults to be sure, however......
    One of the most common causes believe it or not is a faulty brake light switch. Are your brake lights working? If not an easy DIY fix and about £12 for the switch.
    Just be careful to observe how the switch comes out
  3. Re: flashing coil light
    nottinghamshire
    yer the brake lights arn't working
    but the top brake light is??
    could it just be the switch?
    thanks for your fast reply
  4. Re: flashing coil light
    7 Post(s)
    In that case try the bulbs first, then suspect the switch if the bulbs dont sort it.
  5. Re: flashing coil light
    nottinghamshire
    probably not the switch then as the top brake light is working
    the brake light bulbs blown wouldn't throw on the warning light would it?
    ill try the bulbs now and see
    thanks big col!!
    any more advice would be much appreciated cheers..
  6. Re: flashing coil light
    Quote Originally Posted by FLENG2008 View Post
    thanks big col!!
    no more advice really, 9/10 times it's the brake light switch.
    check the bulbs, then the brake light switch, 99% certain it'll be one of the two
  7. Re: flashing coil light
    nottinghamshire
    i just swapped the indicator bulb for the brake light and it worked so it must be the bulbs
    but would the blown bulbs throw on the flashing coil light??
    thanks
  8. Re: flashing coil light
    Mar 2007
    U-96
    ... probably not the switch then as the top brake light is working
    thanks big col!!
    Hi Fleng,
    Please forgive the pun, but this may shed light on the subject;
    Using VAG-COM to diagnose a faulty Brake Light Switch
    Regards,
    TR7
  9. Re: flashing coil light
    nottinghamshire
    Other possibilities (won't necessarily generate a fault code):
    • Fuse 13
    • Faulty brake light bulbs (12V 21W, G4/Bora top bulbs in rear cluster)
    • Bad wiring
    • Relay 13 has also been mentioned (but I don't know enough to comment)
    thanks tr7
    by the looks of it the blown brake light bulbs wont throw on the flashing coil warning light, it must be something else
    so ill have to get it plugged it to read the fault
    thanks anyway
  1. Engine management & flashing coil light
    By JohnWithAGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 09:03 PM
  2. flashing diesel coil on dash
    By mbu10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-03-2008, 02:48 PM
  3. Loss of power, flashing coil light
    By dazzaroon in forum Touran - Sharan - Caravelle
    Last Post: 13-03-2008, 10:37 PM
  4. Sharan tdi 1997 - No brake lights and Heat coil light flashing
    By hawkz_2002_uk in forum Touran - Sharan - Caravelle
    Last Post: 16-09-2007, 07:20 PM
  5. HELP! - coil light flashing on mk4 golf...
    By bobsonic82 in forum Chat - Anything with wheels
    Last Post: 19-08-2007, 08:21 PM
