Thread: Dual mass flywheel failure
  1. Dual mass flywheel failure
    Jul 2008
    I keep reading about failure of the dual mass flywheel on the diesel Passat. How much of a problem is this and what does it cost to fix?
    T
  2. Re: Dual mass flywheel failure
    it's an item that wears gradually over the lifetime of any Tdi, be it a passat, golf or any other models.
    usual price for a new flywheel and clutch, including labour is usually £7/800+ dependant on the model.
  3. Re: Dual mass flywheel failure
    Jul 2008
    Quote Originally Posted by Eshrules-Enterprises View Post
    So it's not a sudden failure which would leave one stranded.
    At what sort of mileage would it be needed? ( Depends on drivers I guess)
    I am thinking of buying a Passat diesel and see some problems listed,
    (catalytic converter?) but then I guess all makes have issues
    Thanks for this.
    T.
  4. Re: Dual mass flywheel failure
    south wales
    there is a conversion kit to change from a duel mass to a normal clutch and fly wheel for around £300 on ebay
  5. Re: Dual mass flywheel failure
    Quote Originally Posted by Tafia View Post
    Thanks for this.
    T.
    the thing is mate is forums are great to find out how to fix and sort a problem so evidently the majority of post are people wanting advice , this is the same on all forums as ive been a member of loads in the past every time i change my car.. just check everything works and take it for a good run and see a car from cold if possible as for the dmf this is a big issue on fords tdci and the vauxhall cdti and im sure there is many others
  6. Re: Dual mass flywheel failure
    Jul 2008
    Quote Originally Posted by littleump View Post
    Many thanks for this.
    As you say, they all have problems.
    Best wishes
    T
  7. Re: Dual mass flywheel failure
    Best wishes
    T
    no worries m8, to be honest ive just bought my passat and have and hope to have no problems, the only way around having 100% fault free strees is buy new with a 3yr warrenty....but thats gonna be ££££
  1. Dual Mass Flywheel - OE or Not OE
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2010, 01:30 PM
  2. Dual Mass Flywheel
    By seventh-heaven in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-11-2007, 07:19 PM
  3. Dual Mass Flywheel Fault?
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 02-09-2007, 07:43 PM
  4. dual mass flywheel
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-06-2007, 01:22 PM
  5. Dual Mass Flywheel
    By Richardm in forum Passat - Archive Topics
    Last Post: 27-03-2007, 02:54 PM
