Thread: A4 B7 Vibration
  1. A4 B7 Vibration
    Aug 2008
    Hi I have an A4 2006 2.0 TDI Manual 66000 miles and out of warranty. I am getting a vibration through the cabin at about 1600 rpm - it happens when in neutral and when driving. An Audi Specialist suggests that it may be the dual mass flywheel but can't be certain.
    Has anyone else experienced similiar?
    Any ideas please
  2. Re: A4 B7 Vibration
    Sep 2008
    I have a similar problem with my A4 quattro 170 HP.
    I have vibrations in the cabin when in neutral. Can feel the vibrations in the wheel, pedals and in the chair too.
    The guys from Audi service said that this is normal behavior for A4.
    Can somebody confirm that ?
  3. Re: A4 B7 Vibration
    Aug 2008
    i had this problem too with only 24000 miles, its not supposed to happen, mine was under warranty and had a new clutch, flywheel, injectors, and tandem fuel pump, still not fixed so dealer swapped the car. I have since found out that it may be the egr system that causes this problem.
  4. Re: A4 B7 Vibration
    Sep 2008
    My A4 is under warranty until November. Tha car has only 45000 km. The guys from the audi service said that is normal to this model to have this vibrations. I don't think so !!!
    Can you please explain what is the egr system ?! Maybe it will help to raise this problem in service.
    Thank you.
  5. Re: A4 B7 Vibration
    Aug 2008
    The exhaust gas recirculation, it puts a bit of exhaust gas into the inlet charge at idle and low throttle applications, its an emissions thing some people remove the whole system, which i myself will do if i get a hint of this problem in future
  6. Re: A4 B7 Vibration
    May 2007
    Leeds Currently (Untill work change their minds again...)
    Howdy. I've a 2005 1.9tdi A4 Saloon and as above there a really noticeable vibraion when she's idling. It stops as soon as the engine revs, even slightly and theres absolutely no problem when driving, just whe sitting idling at lights etc. Granted theres always some vibration with diesels but this seems excessive. Any thoughts/ comments ?
  1. Vibration A6
    By diddly in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-02-2008, 11:14 AM
  2. Vibration
    By SMEG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-12-2007, 01:47 AM
  3. Vibration
    By vexed2007 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-07-2007, 09:48 AM
  4. Vibration
    By Keenie in forum Polo - Derby - Lupo - Fox
    Last Post: 07-07-2007, 11:24 PM
  5. Vibration
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2007, 02:56 PM
