Thread: Bora MKIV (2003) Headlight Adjustment for Europe
  1. Bora MKIV (2003) Headlight Adjustment for Europe
    thud Guest
    Hi Guys,
    I am emigrating to Spain at the end of the week and taking my Bora TDI. Anyone know how to adjust the beam on the headlights so that the left lamp points further down and the right lamp further up to take into account driving on the other side?
    Thanks.
    Steve
    Jan 2006
    Belfast, Ireland
    I know headlight convertors are available. These are sticky material and just sort of block the light coming out. They are stuck on the outside of the lens.
    As for a more permanent job, I'm not sure the headlamps have enough adjustment to allow to change the beam this far. You might have to swap your lamp units for Euro ones. Not sure at all. If you can talk to someone that knows in your local dealership (not Likely!)
    Anyway good luck in you travels!!
    Quote Originally Posted by thud View Post
    Hi Guys,
    Thanks.
    Steve
    as per below, i think youll have to invest in some lamps that are speced for the country your emigrating to, but for now, you could just adjust the beem. the adjustment 'screws' are on the back of the light unit, as you look down at the back of the lights, you will see two white toothed plastic screws, they adjust your beam. id probably try and have a word with the local equivalent of a MOT station over there, ask their opinion on the matter pehaps?
  1. 2003 Polo, changing headlight bulb.
    By nedflanders in forum Polo - Derby - Lupo - Fox
    Last Post: 14-01-2018, 10:35 PM
  2. Changing headlight bulb on Bora
    By SteveC in forum Bora - 1998 - 2005
    Last Post: 29-05-2008, 01:00 PM
  3. headlights from europe in uk
    By jocker01 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2007, 02:11 PM
  4. Audi A3 xeon Headlamp Adjustment for trip to europe
    By ricc in forum Audi A3 - Archive Topics
    Last Post: 30-03-2007, 10:47 AM
  5. Volkswagen back in first place in Europe
    Last Post: 23-12-2005, 09:35 PM
