Thread: 2.8 V6 24v oil sump cracked :(
  1. 2.8 V6 24v oil sump cracked :(
    Jan 2008
    So, after going across one of those lovely square speedhumps in the road (the ones specifically designed for oilsump destruction) I now have a lovely crack in my sump, and my car is currently hemmoraging its oil into a pan.
    *sigh*
    Anyone know what sort of cost I'm looking at for a repair/replacement? I'm told that the gearbox needs to come off as it bolts through the sump?
    Anyone know any reputable VW independants in the Bristol/Weston-super-mare area? (for those that know the area, I'm in Nailsea)
    Should I just take it to a *******?
    Also, anyone had any experience of challenging the council over their frankly dangerous road ornaments?
  2. Re: 2.8 V6 24v oil sump cracked :(
    133 Post(s)
    1989 Post(s)
    It takes about two hours to do and is easy; the box does not have to come off. This is very common on the 4-M as the engine and car sit lower, I would recon that 50% of the sumps we change are on 4-M’s and they certainly aren’t 50% of the production of the Golf 4. A new sump from VW is £100.28 and is part number 021 103 601 L in most cases. It is vital that VW sealant D 176 404 A2 is used and in the correct way as too little will result in leaks and too much in a seized engine.
  3. Re: 2.8 V6 24v oil sump cracked :(
    Jan 2008
    Thanks Crasher, you seem to know EVERYTHING about VW's, you've been a great help!
    If it wasn't 180 miles from here to Nottingham I'd have you doing all the work on my cars
    The rest of the car seems ok but it did hit the ground pretty hard.... is there anything else I should be checking?
  1. cracked thermostat housing!
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 15-05-2008, 06:34 PM
  2. Cracked windscreen on jacking up car.!
    By henry raison in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-04-2008, 04:24 PM
  3. Help i have cracked my rear bumper
    By apeking in forum Golf MK5 - 2004 - 2009
    Last Post: 29-03-2008, 05:19 PM
  4. Catalytic Converter cracked!!!
    By onzarob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2007, 10:01 AM
