Thread: Brakes.......?????
Results 1 to 9 of 9
  1. Brakes.......?????
    Newcastle
    HI,
    I am looking to buy some new brakes and would like some high performance one... disks, pads and calipers
    ANY IDEA's ?????
    Please help (Golf 1.8t ((2001))
    SanderCH...
    Broken Bones Will Heal, But Pride Is Forever
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    What size are standard? My Fabia came with 256mm front brakes which weren't bad as standard, but when I uprated the power a lot, I knew I needed something better. Luckily, the Audi TT 312mm braking system fits right in, and there's a chap on Ebay who sells nearly new kits for about £250. I fitted pagid FR pads instead of the TT oem ones, and now I have a really decent braking system, which also looks the danglies in a 17" alloy.
    Beyond that, you're looking at 323mm brembos, and beyond that 8 pot audi RS4 brakes - 360mm+
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    I fitted a set of black diamond disc from TSR to MKII. Here: http://www.tsr-performance.com/default1.asp
    Also a set of pagid pads. Although they were standard size I notice a great improvemnt. It maybe a cheaper option, or they do brake kit conversions. thats a fair bit more.
    Good luck
    Boardboy
    May 2006
    Looks like TSR performance is re-opening too. Can't wait as they're also chucking in a 1000hp maha 4wd dyno.
    For best bang for buck brake upgrade, I say go for the 312mm system, with performance discs and pads.
    london/ UK
    You could also buy Porsche front calipers (radial mounted) and get brackets made for them and use audi tt standard discs (312mm x25mm) or get audi s4 discs and have them drilled to fit your hubs(330mm x30mm). There are companies on ebay(MBT Engineering) that can get you mounting brackets and even bells to mate with porsche 911 brake discs and then the car will stop on a penny ! You will need 17" wheels to clear the calipers, though !
    Newcastle
    Brembo Front Kit - Grooved
    Sub-category :BKG - VW
    Application :Golf (IV) 1.8i 20V Turbo GTI ; 11/97>
    Price : £315.65 inc VAT
    I think i will go with these thank for your help just one last question whats the difference with grooved or drilled ?
    Cheers again
    SanderCH
    SanderCH...
    i could be wrong here, i hope someone will either back me up or correct me, but my understanding of brakes is that the grooved offer better grip than standard discs, whereas drilled offer a better cooling effect and are a lighter disc. not sure how the two differ on actual braking though? i have heard grooved and drilled wear your discs quicker than standard discs though.....
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by adamss24 View Post
    It would have been handy to state which S4! The B6 S4 has 345x30 front anchors, but they are still inadequate on the S4!!!!
    Rgds
  9. Exclamation Brake discs - grooved or drilled!
    Nov 2006
    Swampyland, UK
    Let's clear this up, grooved discs offer NO performance advantage.
    The makers would have you believe they offer better cooling of the brake pads - that is utter tosh. Better cooling of the brake pads can ONLY be achieved with better cooling air to the brake assembly as a whole, through modified air ducting (or clearing any accumulated crap from any existing ducting). Grooved discs do however increase brake pad wear.
    The only purpose grooved discs serv, is to increase the "Chavtastic" factor.
    At the end of the day, if grooved discs DID offer increased brake performance, then why are they never seen in any kind of motorsport, 2 wheels or 4??
    Drilled discs are a different matter altogether. Although they do assist marginally with cooling (allowing gasses to mix with those in the central ribs), the primary aim of drilling is two-fold. Firstly, drilling helps elminate any "resonance", therefore it reduces brake squeal. Secondly, the most important reason for drilling is to reduce weight. Any quantifiable reduction of weight (or mass, to be correct), on an unsprung component, offers 4 times the gain of the same loss of mass on a sprung item on a vehicle!
    Any more Qs, then the brake doctor will answer away
    HTH, rgds.
  1. brakes
    By dubliner in forum Archive posts
    Last Post: 30-05-2007, 02:00 PM
  2. brakes
    By steve37 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2007, 05:30 PM
  3. What Brakes
    By Tonka73 in forum Passat - Archive Topics
    Last Post: 08-01-2007, 01:11 PM
  4. Better brakes?
    By SteveC123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-12-2006, 07:32 PM
  5. s3 Brakes
    By phillig_s3 in forum Audi A3 - Archive Topics
    Last Post: 26-09-2006, 04:29 PM
