Thread: Electrical fault
Results 1 to 9 of 9
  1. Electrical fault
    Aug 2008
    I pulled into my drive last week and noticed my wife had left the lights on in the golf. When I opened it to turn them off, I saw the switch was already off
    I went to check the lights were definitely on and saw that it was only the drivers side headlight/sidelight and rear light on the back.
    then turned the lights on and everything worked normally. Turned them off, and it went back to its monocle look.
    After playing around for a few minutes, got it to turn off properly.
    Any ideas?
  2. Re: Electrical fault
    134 Post(s)
    2019 Post(s)
    Sounds like the indicator was down/up, they go into parking light mode if the ignition is switched off with the indicators on.
  3. Re: Electrical fault
    Aug 2008
    I'm sure thats not it, with respect. I double checked that, and in fact, knocked the indicator on while I was checking everything.
    If that was the case though, would it cause only 1 side's lights to turn on?
  4. Re: Electrical fault
    134 Post(s)
    2019 Post(s)
    Yes, on the respective side to the indicator.
  5. Re: Electrical fault
    Aug 2008
    Wow, learn something new every day. I'll have a play tonight and see if thats it, but I'm still sceptical. Normally when the indicator is left on a warning alarm sounds.
  6. Re: Electrical fault
    Bournemouth
    did the interior lights work when you opened the door?
    as crasher says it sounds like the parking lights, and if the interior lights did not come on, then it might suggest that the door open switch is sticking, hence no warning of indicator left on.
    long shot though...
  7. Re: Electrical fault
    134 Post(s)
    2019 Post(s)
    Yes, that’s true it does but the buzzer can fail.
  8. Re: Electrical fault
    Near Blackpool
    48 Post(s)
    definatly the parking lights! my mk3 doesnt have a buzzer to warn you tho :S
  9. Re: Electrical fault
    Aug 2008
    My money's on parking lights too. Nothing to say the warning buzzer in the relay's not failed!
  1. electrical fault
    By revres in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-11-2007, 09:26 PM
  2. Electrical fault?!
    By SCORCHIO12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2007, 11:45 AM
  3. A2 electrical fault
    By Hoofcake in forum A2
    Last Post: 14-10-2007, 12:24 PM
  4. Electrical Fault
    By Ukidude in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2007, 12:15 AM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
