Thread: Which brand of oil do u use for pd engines?
Results 1 to 10 of 12
  1. Which brand of oil do u use for pd engines?
    Jul 2008
    I am just about to flush and refill a golf pd130 i got at auction a week ago, it is currently lubricated by treacle.
    So it needs vw 505 01 spec I have scanned around and found;
    millers xfe pd 5L £41
    Castrol EDGE 5W-30 4L £44
    Fuchs TITAN GT1 LONGLIFE III 5W-30 Premium Synthetic 4L £40
    Motul VW SPECIFIC 504 00-507 00 5W-30 5L £45
    Mobil Syst S Special V 5W-30 4L £45
    I intend to change the oil annually / 10k whichever comes first
    which do you people usually use (please give me other options) especially if you got something closer to £30 / 5L - after all i drive a diesel to save money
    cheers
    Gareth
  2. Re: Which brand of oil do u use for pd engines?
    Dec 2007
    Suffolk
    505.01 is 5w40 IIRC, Dont cheap out on it but I think you should be paying about £30 to £35 for some good stuff
  3. Thumbs up Re: Which brand of oil do u use for pd engines?
    Jul 2008
    Cardiff...
    Quote Originally Posted by adzul View Post
    cheers
    Gareth
    Hi Gareth,
    I would use Castrol EDGE 5w-30 (507 00) Just because it's a very good oil and you can pick up 3x1Ltr at Costco for £11 inc vat...
  4. Re: Which brand of oil do u use for pd engines?
    Dec 2007
    Suffolk
    Quote Originally Posted by TimmyTim View Post
    Hi Gareth,
    Use the correct 505.01 spec and you will need more than 3L
  5. Re: Which brand of oil do u use for pd engines?
    Jul 2008
    Cardiff...
    You will need more than 3 Ltrs! But nothing stopping him getting 6Ltrs for £22 and then you've got plenty for top up!(if you need it) 507 00 spec is a higher grade so your putting better oil in you engine!... Go on the Castrol oils site and type in your reg and it will tell you exactly what oil you need...
  6. Re: Which brand of oil do u use for pd engines?
    Dec 2007
    Suffolk
    507.00 is the low ash oil for the later tdi engines with a DPF it does not mean it is a better spec for all engines, Sorry I thought you meant £11 for 1L
  7. Re: Which brand of oil do u use for pd engines?
    Jul 2008
    jeeeez £11 for 3 litres that's amazing,
    quickly googles for nearest costco
    thanks smokey0123 that's exactly the moneysaving tip i was hoping for
    'zul
  8. Re: Which brand of oil do u use for pd engines?
    Jul 2008
    Cardiff...
    cheers
    Gareth
    Quote Originally Posted by smokey0123 View Post
    No problem... But in Gareth posting there must have been a reason why he stated Castrol Edge (507 00) as well as all the other 507 00 spec oils! Sure you can't always use this oil in certain types of VAG power units! But I am aware that this oil is for DPF TDi but I can't see why he couldn't use this it...
    But I stand corrected if this oil is not a higher spec than 505 01 As when I called Castrol to find out what oil I needed for a A6 3.2 FSI I was told by the Oil tech guy that 507 00 surpast all the other specs! And in my case the oil had FSI protection...
  9. Re: Which brand of oil do u use for pd engines?
    Jul 2008
    right scratch that - £20 a year 4 membership of costco and my nearest one is in bristol (i live in Cornwall.....)
    I just cobbled a list of oils together from a couple of sites that had oils suitable for pd engines - I don't want long service oil (which is 507 i think) cause basically no oil lasts that long in normal (rather than ideal) driving conditions.
    I believe that once you get to suitable for pd/ 505 (and any revisions after that) it's good enough for my 130.
    any other good value suggestions?
    thanks
  10. Thumbs up Re: Which brand of oil do u use for pd engines?
    Jul 2008
    Cardiff...
    'zul
    LOL... Think you'll find I gave you that tip mate!
  1. Brand new Mk5 TDI, leaking oil
    By argo wonderer in forum Golf MK5 - 2004 - 2009
    Last Post: 30-06-2008, 06:44 PM
  2. Which Brand of Oil to use??????
    By djl78 in forum Chat - Anything with wheels
    Last Post: 10-04-2008, 09:02 PM
  3. Brand New
    By gteyes in forum New Member Introductions
    Last Post: 19-05-2007, 10:05 AM
  4. best brand of oil for a vento tdi
    By vwnige in forum Vento - 1994 - 1998
    Last Post: 04-05-2007, 12:04 PM
  5. Brand New To The Forum
    By FOOTSY in forum New Member Introductions
    Last Post: 01-04-2007, 09:04 PM
