Thread: Audi sterio system
  1. Audi sterio system
    London
    Hi there,
    Please can anyone tell me if the audi synphony cd/tape/radio (sort of double sterio system) has a separate amplifier or is it built in. As mine all seems to work fine but there is no volume. Today told me that the prev owner might have taken the amplifier of the car. Anybody got any ideas.
    Cheers Mark.
    Nov 2006
    Omaha Nebraska NE USA
    I believe it is an amplifier driven system. That may also depend on your model A4. Amplifiers are typically tucked in behind the passenger side panel in the trunk on a B6. Other times some manufacturers hide them under the front seats, or in some other area in the trunk.
    I would post more info on your car then you might get more specific answers.
    Patrick
    www.AudiA4Mods.com
  3. Audi symphony sterio
    London
    Hi there thanks for the response,
    My audi is a 1999 a4 2.8 quattro
    I have looked in the boot and behind the side panels and cant see anything, do you think someone has taken it out????
    london/ UK
    Does it say Bose on the front speakers grilles ? If yes, then the amplifier should be in the boot, on the left hand side, mounted under the parcel shelf ! If it does not, then the speakers are driven by the stereo's internal amplifier...so, unless you replace the head unit or add an seperate amplifier, you wont get much more volume...It is a good ideea to have someone with a vag-com scan your cars stereo and check the codding of the unit, because the same stereo was fitted across the range and, if the codding is wrong for the sound system, then the equaliser settings will be the wrong ones for your car and may sound flat. Check this link and it might clear things a bit ! http://www.ibiblio.org/tkan/audi/radios/
    Dec 2006
    Wiltshire
    The rear speakers will have a amplifier regardless of the spec of car, that is driven from the pre-out of the Symphony unit. On a saloon the amp is effectively part of the speaker assembly normally on the left hand side as you look in the boot.
    All the head units from this age of car have in-built power for the front speakers, but it will be (Should be!) disabled if the car is BOSE equipped.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    Mar 2007
    I have just bought a used Audi A4 Cabriolet (Sept 04) with a Symphony II and 6 speaker Bose system. I would like to install a Parrot Bluetooth handsfree phone kit.
    However, I need to know if the kit will mute the stereo during calls and operate via the car speakers. Parrot advise it WILL work, if the stereo system is NON AMPLIFIED or just REAR AMPLIFIED. Apparently it WILL NOT work if the system is FULLY AMPLIFIED.
    How do I find out if my system is FULLY AMPLIFIED, REAR AMPLIFIED or NON AMPLIFIED ?
    Thanks!!
    Dec 2006
    Wiltshire
    If you have Bose speakers then the system will be fully amplified.
    The parrot kit should be able to be wired through the Symphony II, to allow full phone integration without any problem - provided that it's connected correctly to the phone input on the back of the unit. (The connections are shown on the lid of the unit)
  1. Not sure what CD goes in my RNS Navigation system.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 11:26 AM
  2. Audi logic 500 alarm system
    By assad in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2007, 07:14 PM
  3. storage system
    By mavlyud in forum Chat - Completely Off Topic
    Last Post: 24-02-2007, 02:01 AM
  4. Flooded Engine Management Control System and A4 Audi '03 Model
    By craig johnstone in forum Chat - Completely Off Topic
    Last Post: 05-01-2007, 02:05 PM
  5. Harddisk / MP3 in car system?
    By hscbaj in forum Passat - Archive Topics
    Last Post: 12-07-2006, 10:57 AM
