Thread: Beginners guide to vag com required!
  1. Re: Beginners guide to vag com required!
    Jul 2008
    even though it says interface found are you sure its on the same com port as in device manager and have you checked the baud rate and tried 9600? thats the biggest reason cables wont communicate. it is possible the cable maybe faulty but recheck the settings and see if that sorts it out
  2. Re: Beginners guide to vag com required!
    Quote Originally Posted by softsorter View Post
    thanks for your suggestions, the cable (from the error shown) is not faulty.
    Meathead, if you want this to be resolved, please keep the issue on my GB thread , so it's easier to keep track of.
  3. Re: Beginners guide to vag com required!
    Jul 2008
    i did state maybe the cable may be faulty not it actually is faulty !
    if the user has all the setting correct like everyone else is using the same item, i only put the comment as a last resort and unless you check everyone before posting and have never had one back then we will assume its not faulty and its in the settings which are preventing the car communicating with the software ?
    regards
  4. Re: Beginners guide to vag com required!
    meathead Guest
    OK, thanks. Perhaps a mod can merge the threads?
  1. Replies: 142
    Last Post: 10-04-2019, 08:42 PM
  2. Beginners luck
    By tahirj89 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2008, 10:46 AM
  3. Where to guide cables?
    By hogiapesda in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-08-2007, 10:08 AM
  4. Buying Guide
    By Nezmond in forum Audi A3 - Archive Topics
    Last Post: 20-06-2007, 02:03 PM
  5. What about a where to get guide
    By paddyboy in forum Passat - Archive Topics
    Last Post: 06-01-2007, 06:43 PM
