Thread: oil filter tool for golf mk4 99 tdi 110
Results 1 to 8 of 8
  1. Question oil filter tool for golf mk4 99 tdi 110
    Mar 2008
    i went to do a service on the car over the weekend i only managed to change the fuel,air,pollen filters, i wanted to change the oil but could not get the filter off !, i thouhgt they were usually hand tight but this f**ker would budge for s**t, do i need a special tool?
  2. Re: oil filter tool for golf mk4 99 tdi 110
  3. Re: oil filter tool for golf mk4 99 tdi 110
    Mar 2008
    Quote Originally Posted by robert310383 View Post
    the latter one with the chain looks like the one i need
    thanks mate
  4. Re: oil filter tool for golf mk4 99 tdi 110
    Mar 2008
    Flippin heck am i goin to need a drain plug removal tool aswell !!!
    I remember using an adjustable wrench on my last car
  5. Re: oil filter tool for golf mk4 99 tdi 110
    Chester-le-Street, United Kingdom
    Quote Originally Posted by natz View Post
    you should manage with an ordinary socket set/ratchet for the drain plug,
    although they can sometimes be absolute pigs to get out,and the access
    isn't great. if you hit problems getting the plug out i would advise forgetting about it and get yourself either a sump pump or bilge pump available from
    ships chandlers,and suck the oil out of the dipstick tube.
    with regard to the filter strap, the chain type is more likely to damage the filter when removing it,which may cause problems if you then find that
    the new filter is the wrong one.also,you need a lot of room to use them
    whereas the other type can be used with a ratchet and extension if access is tight.
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  6. Re: oil filter tool for golf mk4 99 tdi 110
    I've tried a couple of the strap types on my filter (AUM) nothing I tried would budge it, this is the way to go - http://cgi.ebay.co.uk/ws/eBayISAPI.d...ksid=p3907.m29
  7. Re: oil filter tool for golf mk4 99 tdi 110
    Mar 2008
    The guy at GSFparts gave me one of these, but its the 74mm size not sure as ive not tried it yet.
  8. Re: oil filter tool for golf mk4 99 tdi 110
    Southampton, UK.
    Yeah, forget the chains. They're rubbish. Even when used on metal filters, you'll be lucky to get it off without puncturing it and spilling oil from it. And anyway, on the TDI filters (well, the plastic housing for it) they will score the cap badly as there's pretty much nothing for it to grip on to. It'll probably work, but expect to be forced to buy a new one after a few changes. Got my metal removal tool from GSF and it makes the filter removal a piece of cake.
    With regard to the sump plug, it's just a 17mm (I think) bolt, but best removed with a socket as it is slightly recessed. This should be renewed for each change.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  1. Replies: 7
    Last Post: 19-01-2012, 07:45 PM
  2. Golf V5 Oil Filter
    By Supatek in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-09-2007, 10:58 PM
  3. Oil filter tool?
    By vroooOOOM in forum Passat - Archive Topics
    Last Post: 29-12-2006, 05:26 AM
  4. Oil filter tool for Mk5 TDI 103PS
    By NRG in forum Golf MK5 - 2004 - 2009
    Last Post: 24-08-2006, 10:41 PM
  5. Mk4 golf air filter
    By daniel_louis in forum Chat - Completely Off Topic
    Last Post: 16-02-2006, 03:03 PM
