Thread: New user with faults
  1. New user with faults
    Southern County Softy
    20 Post(s)
    hi All
    Not sure if i should post here on in car specific section.
    New user to VagCom and have scanned the car !
    00858 I know this relates to the anntenna and is a common fault.
    Where can I find the Amp that the fault relates to.
    01332
    01333 Both relate to door modules but can't find anything on the wiki page about these faults.
    01370
    00962 Both relate to alarm triggers !
    I have copied the scan and cleared the faults, my plan is to scan again at the weekend and see if any faults have returned.
    If anyone has thoughts !!
    A4 2.5 tdi QS (mapped)
  2. Re: New user with faults
    Angus, Scotland
    Hi Kite,
    Can you put up the full auto scan, that will give us info on car type and a better undersatnding of where the errors are coming from.
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: New user with faults
    20 Post(s)
    Heres the scan
    Thursday,31,July,2008,12:10:39:55371
    VAG-COM Version: Release 704.1
    Data version: 20070422
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E64A070388 Mileage: 83110km/51642miles
    Address 01: Engine Labels: 059-907-401-AKE.LBL
    Part No: 8E0 907 401 N
    Component: 2.5l V6 TDI G000SG 0003
    Coding: 02005
    Shop #: WSC 63351
    Part No: 00006059
    Component: 130 106KC318_1.V14550943387
    WAUZZZ8E64A070388 AUZ6Z0C0229648
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04455
    Shop #: WSC 06435
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Part No: 8E0 820 043 AH
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63351
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 01011
    Shop #: WSC 63351
    2 Faults Found:
    01332 - Door Control Module; Passenger Side (J387)
    49-10 - No Communications - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 3002
    Coding: 0010602
    Shop #: WSC 63351
    Address 16: Steering wheel Labels: 8E0-953-549.LBL
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 01041
    Shop #: WSC 63351
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Part No: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 01400
    Shop #: WSC 00185
    Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
    Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
    Component: RNS-E HIGH EU H48 X---
    Coding: 0301111
    Shop #: WSC 06348
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 52
    Time Indication: 0
    Date: 2008.05.09
    Time: 15:27:27
    Freeze Frame:
    Mileage: 655350 km
    Count: 2907
    Clock: 20:36
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1311
    Coding: 07919
    Shop #: WSC 00185
    Part No: 8E2959802
    Component: Tőrsteuer.FS BRM 0003
    Part No: 8E2959801
    Component: Tőrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0003
    Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0003
    6 Faults Found:
    01336 - Data Bus for Comfort System
    80-10 - Single-Wire Operation - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01334 - Door Control Module; Rear Right (J398)
    Address 55: Xenon Range Labels: 4Z7-907-357.LBL
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    Address 56: Radio Labels: 8E0-035-192-RNSE.LBL
    Coding: 0301111
    Shop #: WSC 06348
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 52
    Time Indication: 0
    Date: 2008.05.09
    Time: 15:27:27
    Freeze Frame:
    Mileage: 655350 km
    Count: 2907
    Clock: 20:36
    Address 76: Park Assist Labels: 8E0-919-283-8E2.LBL
    Part No: 8E0 919 283 A
    Component: Parkingsyst. A4 RDW D08
    Coding: 00104
    Shop #: WSC 63351
    End --------------------------------------------------------------------------------------------------
    Thursday,31,July,2008,12:20:02:55371
    69 75 76 77
    Coding: 02005
    Shop #: WSC 63351
    Part No: 00006059
    Readiness: 0 0 X X 1
    Coding: 04455
    Shop #: WSC 06435
    Coding: 00000
    Shop #: WSC 63351
    Coding: 01011
    Shop #: WSC 63351
    2 Faults Found:
    Coding: 0010602
    Shop #: WSC 63351
    Coding: 01041
    Shop #: WSC 63351
    Coding: 01400
    Shop #: WSC 00185
    Coding: 0301111
    Shop #: WSC 06348
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 52
    Time Indication: 0
    Date: 2008.05.09
    Time: 15:27:27
    Freeze Frame:
    Mileage: 655350 km
    Count: 2907
    Clock: 20:36
    Coding: 07919
    Shop #: WSC 00185
    Part No: 8E2959802
    Part No: 8E2959801
    Part No: 8E0959801A
    Part No: 8E0959802A
    6 Faults Found:
    35-00 - -
    35-00 - -
    Coding: 00060
    Shop #: WSC 63351
    Coding: 0301111
    Shop #: WSC 06348
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 52
    Time Indication: 0
    Date: 2008.05.09
    Time: 15:27:27
    Freeze Frame:
    Mileage: 655350 km
    Count: 2907
    Clock: 20:36
    Coding: 00104
    Shop #: WSC 63351
    End
  1. new faults on vag-com help please
    By zorgman in forum Touran - Sharan - Caravelle
    Last Post: 10-02-2008, 04:54 PM
  2. Eos faults
    By hitachizx in forum Eos
    Last Post: 11-01-2008, 11:49 PM
  3. more vag com faults
    By Dozz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2007, 06:15 PM
  4. A3 1.8T - faults to look for
    By Graham in forum Audi A3 - Archive Topics
    Last Post: 01-08-2006, 11:12 PM
  5. VAG-COM Faults
    By anoak in forum Passat - Archive Topics
    Last Post: 14-07-2006, 09:25 PM
