Thread: injector types A6 PD engine
  1. injector types A6 PD engine
    I need to replace an injector on my A6 AJM PD engine..The ones I should use are 045 130 073 T or X...I have been offered 4 injectors with the part number 045 130 073 AL...I think these are from the higher 96kw engine. Would it make any difference if I used them in my 85kw engine. TIA
    Mick G
    london/ UK
    Hi, AJM has a lower compression ratio 18:1 and AWX/AVF has a 19:1 compression ratio. As far as i know, the only difference between 115 PD and 130 PD are the injectors and more agressive ECU fuelling maps so they may smoke a bit at the beggining while ECU learns how to ballance/control the injectors but you deffinatelly will love the power ! Also a wise move if you consider a remap/chip tuning then upgrading the turbocharger from a pd 150(straight swap only need to buy a 20 quid rubber hose to conect outlet to IC pipe). Do a search on tdiclub.com as they have done that beffore also look for more advice.
  3. Good Advice
    Thanks for the advice Adam. The guy only wants £100 for the 4. Will pick them up and change them next week. I will let you know how it runs
  4. Injectors fitted
    put in the new injectors and it runs like a dream. Thanks for the advice
  5. Re: injector types A6 PD engine
    Warrington
    Hi, how difficult was the injector swap on the PD engine?
  6. Re: injector types A6 PD engine
    Aug 2007
    Wicklow
    Where are the injectors on a PD engine (AJM)?
    I had a scout around the other day and couldn't see them. Do the PD engines have the 4 injectors like say an AFN does?
  7. Re: injector types A6 PD engine
    Warrington
    Hi mate, the injectors on the AJM engine are: 038 130 073 F
    I have a set of 4 if you are interested. Only removed them as part of an upgrade from my own car. Give me a call on 07771895084 if you want them.
    Cheers Dave
  8. Re: injector types A6 PD engine
    Warrington
    Remove the rocker cover, the injectors are sat under the 4 cam driven rocker arms. See my posts for a link on how to swap them.
  9. Re: injector types A6 PD engine
    Aug 2007
    Wicklow
    Cheers for that. I'd looked under the bonnet again the other day and still couldn't see them.
    I was going to get them refurbished or replace them but it looks like too complex a job for me after reading that procedure. Don't really trust myself to do anything that involves opening the engine up. Looks like it'll be Redex for me!
  1. Injector Problems
    By A6 Simmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2008, 08:19 AM
  2. Injector Nozzles
    By jamie211983 in forum Passat - Archive Topics
    Last Post: 02-04-2007, 12:22 AM
  3. Injector problems
    By Geoff Banks in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-11-2006, 06:46 PM
  4. Injector Problems
    Last Post: 13-09-2006, 02:04 AM
  5. blocked injector !!??
    By smiler in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2006, 03:49 PM
