Thread: scirocco gt2 engine cuts outs, HELP!!!
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: scirocco gt2 engine cuts outs, HELP!!!
    no only happens when it gets hot..
  2. Re: scirocco gt2 engine cuts outs, HELP!!!
    131 Post(s)
    1973 Post(s)
    Has it been happening more since the weather turned cold? Have you checked the condition of the fuel filler neck to see if it is corroded or has it been replaced recently?
  3. Re: scirocco gt2 engine cuts outs, HELP!!!
    all the fuel system was replaced before i bought the car .. only had the car about a month.. i want the engine to go in my caddy but i want to make sure it runs all ok before i do so. just cant think what it can be i am thinking its the carb but what would do it.. dirt in the carb or somthing. just dont want to spunk out for a new carb if its not that.
  4. Re: scirocco gt2 engine cuts outs, HELP!!!
    131 Post(s)
    1973 Post(s)
    More than likely it is dirt in the system or carb icing due to a failed air pre-heat system or a blocked manifold to head grommet.
    By the way, please don’t use unpleasant words like that on this forum; you will get your wrists slapped by the mods.
  1. Engine Cuts Out
    By sebw in forum Touran - Sharan - Caravelle
    Last Post: 29-04-2008, 01:31 PM
  2. Engine Cuts Out
    By Sol in forum Golf MK2 - 1984 - 1992
    Last Post: 21-04-2008, 02:36 PM
  3. Engine Cuts Out
    By adunky in forum Chat - Anything with wheels
    Last Post: 10-04-2008, 08:44 AM
  4. Engine cut outs, warning lights coming on!
    By barnaby82 in forum Archive posts
    Last Post: 04-02-2008, 07:59 PM
  5. Fitting a Golf 16v engine into a Scirocco
    By carl perkins in forum Scirocco - Corrado
    Last Post: 03-09-2005, 08:11 AM
