Thread: rough idle
  1. rough idle
    Jul 2008
    hi, i have a problem with my car its a 1.8t, engine code AUQ. when it starts from cold the tick-over starts at about 1200rpm and then drops down to 800ish, at this point the needle fluctuates up and down slightly and there is quite a loud flappy type noise (almost like the rotor noise of a helicopter). it seems worse if the climatronic is on. when i drive off it is then very unresponsive and jumpy. is it a simple cure or something far more sinister.
  2. Re: rough idle
    Mar 2008
    hey fella,perhaps the amm needs replacing or even the temp sender????
  3. Re: rough idle
    Jul 2008
    cheers for the reply slim, i might sound a bit dopey but whats the amm. the temp sender i think was changed last year when i had a coolant temp fault.
  4. Re: rough idle
    Mar 2008
    if you have a look on the "search this forum"tool,there s lots of info on them they're also called maf,mas airflow meter.tells you how to see if its not working.
    Mind you it could also be the throttle body needs cleaning,just a idea???
  5. Re: rough idle
    i have the same problem with my golf gti,i replaced the maf sensor,n75 valve, and temperature sensor and cleaned the throttle body but this didnt solve anything.
    the garage are saying its the fuel pump that need to be replaced so i cant believe in them anymore
  1. 96 polo 1ltr rough idle
    By hibz in forum Polo - Derby - Lupo - Fox
    Last Post: 04-06-2008, 12:18 PM
  2. A6 rough idle
    By evandar in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-03-2008, 06:30 PM
  3. 97' A6 rough idle problem
    By plovett26 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-07-2007, 09:31 PM
  4. 97 1.8 Non Turbo Rough Idle / Hesitation
    By RobNorwich in forum Passat - Archive Topics
    Last Post: 29-03-2007, 07:03 PM
  5. Rough on idle/drive 1.9TFI 150,
    By RickT in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-01-2007, 11:36 AM
