Thread: Bora TDI Hot Start Probs
  1. Angry Bora TDI Hot Start Probs
    Jun 2006
    Droitwich, Worcestershire
    Hi, i have got a 1.9 TDI Bora on a 'W' plate (2000) with 78k on the clock. Recently ive noticed that it takes longer and longer to start when the engine is hot. It starts fine from cold and the glow plugs only take seconds to heat up.
    Is it a fuel problem?? Would really appreciate some advice!!
    Thanks, Dave.
    When you say takes longer to start, do you mean engine has to turn over more than usual?
    I ask because I had a similar problem with my 1999 1.8T. When trying to start when warm, it took a number of attempts. Finally it failed and just turned over without starting.
    Problem was sorted by the VW road side assistance. A temp sensor was faulty. Cost about £30 for the part.
    Jun 2006
    The engine starts with one turn of the key, but it just takes longer when it's hot than cold, and it appears to be getting worse.
    Could you give me a bit more info on the temp sensor you had replaced?? Would like to do the job myself if i could! Try and save a few pennys.
    Thanks for your help.
    I do not know what the part number is, but the sensor was in the water pipe just before it enters the radiator. But, that is on a 1.8t, could be different on your engine.
    Very easy to change. It involved removing one circlip and pulling the sensor out. Took the repair guy about two minutes.
    He diagnosed the fault using the VW software. You could ask your local dealer to see if they will diagnose your problem free of charge.
  1. mk 2 gti 8v probs
    By mk2.8v in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-06-2007, 06:59 PM
  2. Hey All - Any ESP probs?
    By Sark in forum New Member Introductions
    Last Post: 25-05-2007, 10:36 AM
  3. Bora Break Probs.
    By Stopher in forum Chat - Completely Off Topic
    Last Post: 30-10-2006, 10:50 PM
  4. Bora Central Locking Probs!!
    By DiverDave in forum Bora - 1998 - 2005
    Last Post: 23-09-2006, 09:37 PM
  5. Replies: 0
    Last Post: 17-09-2006, 10:31 AM
