Thread: WATER TEMP AND OIL GAUGE NOT WORKING - A6
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. WATER TEMP AND OIL GAUGE NOT WORKING - A6
    Hi All,
    Both my Water temp and Oil gauge are not working on the instrument panel of my Audi A6 (2001). They both packed up together although under long journeys (with temperature) they show a small sign of registering low readings.
    I have read many forums that indicate the Instrument Panel may need replacing but would this be the case if two gauges went at the same time?
    Many thanks
    Canada
    Hi, I've moved your post to the correct area, should get a better response here
    On the subject the instrument panel, they can be tempramental on most of the VW audi range. But there are other causes.
    The best plan first would be to get the fault codes read for the instrument cluster as this would help allot.
    The Water temperature sender is very tempermental, but i don't ever recall seeing a complaint about the oil gauge. the fuel one does play up more.
    There are a few companies who refurb the cluster, or you can get one from the dealer, but I've seen quotes for £400+
    Let us know how you get on.
    Rob
    Many thanks Rob,
    I was hoping and preying for a quick cheap fix. Looks like a main dealer may be my only option.
    Regards
  4. A6 Oil and Temp guages not working
    Feb 2007
    Hi I also have an A6 2.0 SE (2001) that has suffered similar fate in the last week. Neither the oil or coolant temp gauges are working. The coolant gauge will move with some speedy driving but still does not reach 'normal working' mark.
    Was wondering if you had managed to resolve your problem?
  5. A6 Oil and Coolant guages not working
    Feb 2007
    Hi again. It appearsyour problem might be with the thermostat apparently this is not uncommon with 2000/2002 year A6's. I took mine to an independent VW Audi garage in Dorking who were extremely helpful and a darn site cheaper than main dealer!..still cost £280. They replaced both the thermostat, housing and sensor. Since then both guages are working fine. Hope this helps
  6. Re: WATER TEMP AND OIL GAUGE NOT WORKING - A6
    Jul 2008
    I've just seen this thread, having posted a similar question about Oil/Water gauges on my 1997 A4.
    Did you have any luck?
    cheers, Zulu.
  7. Re: WATER TEMP AND OIL GAUGE NOT WORKING - A6
    Feb 2007
    Hi Took to independent Audi garage Tutts in Dorking. Transpired it was something to with the thermostat and temp sensor. Cost me about £200 to have it repaired. Andy
  8. Re: WATER TEMP AND OIL GAUGE NOT WORKING - A6
    Jul 2008
    cheers, Zulu
  9. Question Re: WATER TEMP AND OIL GAUGE NOT WORKING - A6
    rayseakayak Guest
    I have recently purchased an AUDI 2.5 TDI SE AVANT year 2001,
    I noted the coolant temperature was very low, around 60~70°C, the temperature does increase when travelling at higher speeds on the motorway, this would indicate that the element is faulty. Does anyone know where the thermostat is located, it is certainly not visible from the top of the engine so I assume it is somewhere under it. Running at too low a temperature is liable to increase cylinder wear rates so I need to replace the element asap, any help would be gratefully received.
    Rayseakayak
  10. Re: WATER TEMP AND OIL GAUGE NOT WORKING - A6
    Canada
    Quote Originally Posted by rayseakayak View Post
    Rayseakayak
    Hi, your temperature reading could be one of many thing including the thermostat, but not thermostat common problem for poor temp readings. the temp sender is a common faulty part, also the water pump has a habit of failing as well. the impeller is plastic and detaches from the spindle
    I would get a code scan done first to rule out the sender then go form there.
  1. a3 temp gauge!!!
    By shaboy in forum Audi A3 - Archive Topics
    Last Post: 01-02-2008, 03:22 PM
  2. temp gauge
    By garying3980 in forum Passat - Archive Topics
    Last Post: 11-02-2007, 03:06 PM
  3. a4 2.8 oil temp gauge
    By markcass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2007, 01:42 PM
  4. TEMP GAUGE
    By GARY in forum Passat - Archive Topics
    Last Post: 30-11-2006, 05:14 PM
  5. temp gauge not working
    By chrispey in forum 80 - 90
    Last Post: 28-07-2006, 02:46 PM
