hey, i've got a scirocco scala 1.8 injection. keeps blowing fuses on the fuel pump. i put a new pump on, but the problem persists. there is a short circuit somewhere between the fuse box and pump wiring as both wires go straight to ground.
is there a controler somewhere for the pump thats knackered? i tried conecting the pump straight to the ignition switch and it works but i believe it needs to prime and then stop pumping when the engine is not running?
there is power going to the fuse obviuosly to blow it so i'm guessing the relay is working. old pump also works off the car so i've already wasted a hundred quid!
i know this is posted in the wrong place but didn't know where to put it
any advice would be massively appreciated
