Thread: no lights on dash clocks
  1. no lights on dash clocks
    Jul 2008
    drove home last night and the lights that are on the speedo/rev counter etc have stopped working...any ideas where to start?
    its a passat 1999 1.8 petrol.
  2. Re: no lights on dash clocks
    Kinross Scotland
    Hi, I have looked at the wiring diags untill I am cross eyed on this one and I would start at the lighting controll switch and the dash display dimmer switch.
    If the rest of the dash lights are working then as all of the dash lights seem to be on the same feed from the dimmer control, then this would point to a bad connection to the dash insert.
    You can see and try the connectors( behind the speedo) if you remove the fuse panel cover and the trim panel above the pedals (four screws in total)
    If all of the dash lights are out then check the fuses.
    This may not be your problem, but it is the start of an illimination process.
    Regards Richard
  3. Re: no lights on dash clocks
    Jul 2008
    ok,thanks but the worst thing has happened.... the lights have came back on themselves...
    so not sure what the problem was and it will come back to haunt me later on no doubt!
  1. A4 dash clocks spiked
    By boothy 68 99 08 in forum Chat - Completely Off Topic
    Last Post: 13-08-2008, 12:58 PM
  2. Dash lights
    By Bilbobaggins in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-12-2007, 12:32 PM
  3. Dash Lights
    By chris.fulton in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 04:05 PM
  4. Help Needed With Dash Clocks!!
    By scoobyra in forum Archive posts
    Last Post: 29-04-2007, 08:31 PM
  5. dash lights
    By howez in forum Passat - Archive Topics
    Last Post: 31-03-2007, 12:48 AM
