Thread: HELP 2001 passat locking
  1. HELP 2001 passat locking
    Jul 2007
    chepstow
    i have a 2001 passat tdi and when i press lock on the remote all doors lock and then the pasanger door unlocks straight away press it again and all doors lock and stay locked (sometimes it works with no prob at all) PLEASE HELP
  2. Re: HELP 2001 passat locking
    Aug 2008
    I have exactly the same problem with my '98 variant. Except that pressing twice won't help, as the lock goes down and then jumps up always. The problem has been there for years I think, and they tried to fix it in the service serveral times, but sooner or later the problem comes back. Sometimes it works like a charm for a few days but now it's been like that for a while.
    Anybody know how to fix this? It's really annoying to go close it manually every time you leave your car.
  3. Re: HELP 2001 passat locking
    134 Post(s)
    2022 Post(s)
    You need a new lock unit.
  4. Re: HELP 2001 passat locking
    Dec 2007
    Suffolk
    Under the passenger side carpet the is the central convieniance ecu, Check the connections are clean and not corroded,it is dry and the wiring going to it looks ok. They normally get full of water because of the drain grommets getting bocked under the scuttle (the bit under the wipers) and cause all sorts of faults like this.
  1. 2001 A6 2.7t Central locking glitch
    By gazza57 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-05-2008, 10:23 PM
  2. 2001 2.3 V5 Passat Estate - Central Locking!
    By Veedubmad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2008, 03:45 PM
  3. Central Locking problem 2001 TDi
    By Deagle in forum Golf MK4 - 1999 - 2004
    Last Post: 18-01-2008, 03:00 PM
  4. Audi A4 2001 central locking issues
    By jasonaudiA4 in forum Chat - Anything with wheels
    Last Post: 10-08-2007, 11:10 AM
  5. vw passat 2001 remote central locking
    By laytj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-07-2007, 03:38 PM
