Thread: Water in rear passenger footwell
  1. Water in rear passenger footwell
    My freind has2003 pasaat tdi 130.
    Recently he noticed that the rear passenger footwell was soaking on the drivers side but not the other side, also a bit wet in the boot but not as much.
    Any ideas??
  2. Re: Water in rear passenger footwell
    Tyldesley, Manchester, UK
    Not sure if you mean the rear nearside or offside, assuming you mean the nearside then it is the area immediately in front of the bulkhead under the bonnet. Covered with a piece of plastic trim in the B5.5. There are two drain holes which block and cause it to fill up, this then leaks through a joint in the A/C inlet duct and into the car. It may appear in the front and/or rear. If left too long in the front it can damage the comfort module and may even prove to be expensive to repair.
    Do a search on the forum it affects A4's, A6's Passat's and one or two others.
    It could just be a door seal and the boot issue possibly unrelated and maybe just the boot lid seal?
    One German, Two Italian.
  3. Re: Water in rear passenger footwell
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by MalcQV View Post
    Seconded, another example of teutonic brilliance
    Nothing to see here, move along..
  4. Re: Water in rear passenger footwell
    Quote Originally Posted by Hex69 View Post
  5. Re: Water in rear passenger footwell
    Jul 2008
    Beverley, East Yorkshire
    Hi Malc
    If you mean the passenger side front - I had the same problem - all sorted via the advice from this forum.
    Loads of threads dealing with the same thing, but this link explains the full solution including pictures.
    There are some technical issues related to the water leak - servo problems and comfort module issues - search for these as well.
    I also still have a slight leak from the pollen filter housing awaiting repair - another common problem it seems.
    http://www.weirdlittlebiscuit.com/passat/leak/
    Good luck
    Laurie
  6. Re: Water in rear passenger footwell
    Yes Laurie I mean the passenger front. Not sure what side MAZI means though
    I am well aware of the problem and check mine regularly. I don't park it under foliage at all either
  7. Re: Water in rear passenger footwell
    Jul 2008
    Sorry Malc - replied to the wrong thread - just having a senior moment! I still find it difficult to understand how such 'quality' cars have basic design faults like the drain bungs. Spoke to VW today (well the local parts department) and asked if there was a recall on the pollen filter box leak - apparently cars over 4 years old are no longer re-called, although the issue is now on the service schedule!
  1. water in the rear passenger footwell!
    By sompop in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2010, 06:49 PM
  2. Alhambra - water in passenger footwell
    By Ayjay in forum Alhambra
    Last Post: 30-03-2009, 09:07 AM
  3. Water in Passenger Footwell
    By Paulpro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-03-2009, 11:52 PM
  4. Rear Wiper Water Leak in Passenger Footwell
    By mike_watts in forum Alhambra
    Last Post: 24-02-2008, 11:49 PM
  5. Water in rear passenger footwell
    By avantiblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2007, 01:43 AM
