Thread: Remove Front Ashtray
  1. Remove Front Ashtray
    Jul 2008
    I have an 2007 Audi a4 Quattro 2.0 and would like to remove the entire front ashtry so that I can fit in a satellite radio in there and still be able to close the cover.
    Note: the ashtry includes a cigarette lighter, which I do not need and would need to disable.
    Any help or suggestions on this would be appreciated. Thanks.
  2. Re: Remove Front Ashtray
    Norwich
    Have you got the convertible A4 as I have been in Saloon and Avant B7s and the cigarette lighter was always next to the hand brake unless this is some smokers package that Audi do as an option
    The ashtray is relatively easy to remove in my car- if you post a pic of your interior I may be able to help.
  3. Re: Remove Front Ashtray
    Jul 2008
    I have a sedan and I live in the United States, if that makes a difference. I will post the pictures shortly.
  4. Re: Remove Front Ashtray
    Jul 2008
    Here are the pics:
  5. Re: Remove Front Ashtray
    Norwich
    Ah OK. I take it you want to put the Sat Nav unit in place of the radio?
    Is it going to be the Audi Sat Nav, if it is it should be a straight swap as you have the double DIN (Large) head unit installed and you won't need to take out the ashtray.
    To remove the head unit you will need the 4 Audi removal keys
    Part Number: 8E0 051 530
    If you are still looking to remove the ashtray then I will post pics up tomorrow evening showing how it is done.
    I notice you have auto transmission, my pics will show how it is done on manual transmission but I'm guessing the process is the same.
  6. Re: Remove Front Ashtray
    Jul 2008
    I have a removable satellite unit that I want to place in the ash tray space with the wires etc. This would be a good spot to keep the unit out of site so I do not have to take it with me everytime I go somewhere.
    The other issue that I can see is the cigarette lighter would need to be deactivated so it does not cause a problem when disconnected. Any thoughts on what to do with that?
  7. Re: Remove Front Ashtray
    Norwich
    I understand now- you want to create a storage area by removing the ashtray completely. I'm not sure if this will be possible as the silver slide up lid is attached to the ashtray unit which is removed in one go meaning you will be left with a hole
    You will see in the photos I will post up later what I mean.
  8. Re: Remove Front Ashtray
    Jul 2008
    At a minimum it would be nice to see if I could feed the wires up through that area so I could hide the wires in that compartment.
    Any suggestions?
  1. Please Help how do i remove front shocks on A3
    By sluggs1 in forum Audi A3 - Archive Topics
    Last Post: 15-06-2008, 08:21 PM
  2. Can you remove front headrests?!
    By ross_Darroch in forum 80 - 90
    Last Post: 24-03-2008, 03:53 PM
  3. Hockey tickets stuck behind front ashtray
    By cville85 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2008, 01:13 AM
  4. Tool to remove bottom front arm A4 1.8T
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2008, 02:09 AM
  5. How To Remove Front Ashtray Cover
    By gunshotx in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2008, 09:54 AM
