Thread: Where does this black plastic bit come from ?
  1. Where does this black plastic bit come from ?
    London
    Short question : Where does this attached black plastic bit come from, please ?
    http://www.flickr.com/photos/27466575@N03/2688993340/
    The full monty: I replaced my window regulator and there are 2 "plastic rivets" that stablise the passenger door lock mechanism to the metal regulator frame. I dunno if these plastic rivets are "once only use intended " but I lost one and the other seemed lose - so I used the attached (see picture) instead which worked a treat.
    I cannot remember what part the attached came from, is it a push fit to hold some kind of carpet or panel in position ?
  2. Re: Where does this black plastic bit come from ?
    135 Post(s)
    2039 Post(s)
    The plastic bracket to the door lock is not supposed to be removed; you should disconnect the door lock from the door shell and remove the door panel with the lock unit attached. The way you have done it is not a problem though.
  3. Re: Where does this black plastic bit come from ?
    Oct 2005
    It looks like the cap that covers the upper most screw (the one that holds the door lock cylinder in place) on the end of the door.
  4. Re: Where does this black plastic bit come from ?
    London
    Hi mycarsavw,
    The cap you mention has smooth sides and is shorter with what one might call a short hollow barrel without the "sideways teeth".
    But thank you anyway...
    Regards
    Kevin
  5. Re: Where does this black plastic bit come from ?
    London
    Oh dear well we all learn (eventually).
  6. Re: Where does this black plastic bit come from ?
    London
    Crasher: Thank you. As a newbie, perhaps I was not clear. When I replaced the regulator, the new mechanism was supplied all attached to the whole metal "breastplate". Consequently I had to transfer the door lock and speaker from the old to the new metal "breastplate".
    Regards
  7. Re: Where does this black plastic bit come from ?
    135 Post(s)
    2039 Post(s)
    OK, clear now. The plastic bracket isn’t important, it is just an assembly aid.
  1. Back to Black and other Black cleaners
    By kimandsally in forum General Detailing/Cleaning Questions
    Last Post: 17-10-2008, 09:20 AM
  2. Plastic cover under engine
    By poseidon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2008, 12:02 PM
  3. AUDI plastic key tag
    By Raszler in forum Audi A4 - Archive Topics
    Last Post: 12-02-2008, 06:12 PM
  4. plastic pipe to intercooler.
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-07-2007, 09:42 PM
  5. golf mk 3 exterior black plastic trim
    By mrfunk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-08-2006, 08:16 PM
