Thread: Golf GTi Mk 1 Oil pressure monitor switch unit
  1. Golf GTi Mk 1 Oil pressure monitor switch unit
    Mar 2008
    Hi - I have a low pressure warning light and buzzer coming on even though the oil pressure is fine and the oil pressure sender unit is functioning. Having consulted the wiring diagram (in my Haynes manual) I suspect that the oil pressure monitor switch unit is at fault. Can anyone tell me where this is located please?
    Thanks.
  2. Re: Golf GTi Mk 1 Oil pressure monitor switch unit
    Aug 2007
    there are 2 pressure switches on a gti one on the head and one on the oil filter housing have you checked both? further to that i had a long drawn out battle once to get a GX tacho cluster to work properly in an 1100, the oil light just wouldn't go off and i think this monitoring unit you speak of might be in the cluster. i tried and never succeeded in fooling it to run on one switch so if your cluster is not from a gti you could be in for a bit of a marathon.
  3. Re: Golf GTi Mk 1 Oil pressure monitor switch unit
    Sounds like a break in the wiring somewhere along the line would be a more likley cause in a 25 year old car, since the 'monitoring' in the binnacle is simply measuring the resistance between the switch and ground.
    Just my 2p
  1. oil pressure switch?
    By james80tdi in forum 80 - 90
    Last Post: 27-05-2008, 04:34 PM
  2. Tyre Pressure Monitor
    By Black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-05-2008, 08:55 AM
  3. ac pressure switch.1.9 gt tdi golf
    By stuffs in forum Golf MK4 - 1999 - 2004
    Last Post: 12-07-2007, 03:57 PM
  4. Oil Pressure Switch
    By e6m6a6 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-06-2007, 05:42 PM
  5. Golf V5 oil pressure switch location???
    By neil b in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2007, 05:40 PM
