Thread: rubbing noise n/s front
  1. rubbing noise n/s front
    Jul 2008
    hi all
    new to the forum and have an A4 2.4 estate, car is just bought and has one or two little niggles, one of which is a rubbing noise when on a r/h lock, even a small turn makes it occur but doesn;t do it going backwards, have checked brakes and for anything catching, it's like a hssh hssh sound if you get my drift, could this be a bearing or cv problem? i am experienced with cars but this nis not your normal bearing or cv noise.
    PS noise apears from l/h front wheel
  2. Re: rubbing noise n/s front
    Jul 2008
    Just for future reference, the noise turned out to be the tyre! Also located the oil leak, coming from l/h cam cover.
    Anyone done a cam belt change on one of these? can it be done easily
  3. Re: rubbing noise n/s front
    Jul 2006
    What was it on the tye causing the noise? I'm getting a similar rubbing hssh hssh noise, at regular intervals, linear to the speed i am travelling (ie at 5mph it goes hshh................hshh, at 10mph it goes hssh.... hssh.... hssh)
    I've looked everything over and cannot see how it could be the tyre causing the noise?"$ Maybe ill try the spare wheel... i thought it was a bearing on the go.
  4. Re: rubbing noise n/s front
    Jul 2008
    Yes, sounds exactly the same as mine, the tyre was badly worn on the edges, and that side track rod end has a bit of play, can't say what was causing the noise apart from it was definately the tyre, i got someone else to drive and ran around like a you know what listening and tried the spare and noise was gone.
  1. Rubbing, grinding noise when turning left
    By trousdala in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2008, 09:24 PM
  2. accelerator rubbing noise, polo
    By 1043cc in forum Polo - Derby - Lupo - Fox
    Last Post: 17-04-2008, 08:39 AM
  3. Mk V Creaking noise from front
    By JefB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-06-2007, 09:08 PM
  4. Front end noise
    By Gaz the Cab in forum Passat - Archive Topics
    Last Post: 29-11-2006, 04:41 PM
  5. A4 TDI 1.9 Front suspension noise?
    By tubbs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2006, 12:05 AM
