Thread: tdi 130 pd golf wont go...
Results 1 to 10 of 18
  1. Angry tdi 130 pd golf wont go...
    hi,new member here looking for some help. my tdi 130 pd golf 2002 has decided that it dos'nt want to play any more. the engine turns over but it will not start the ignition lights go out as normal but the ABS and traction control lights stay on. the injectors are away to be tested as a sparky says that they are recieving 10 amps a piece, which is far to much. there is nothing comming from the ECU and no diagnosis information, it all seems to be dead.
    any information/help please, been 5 weeks now without my motor
    cheers ian.
    update. 17/1/07
    injectors back from been tested, the solenoid within each of the injectors are siezed due to some sort of fuel contamination. this may account for the high amps going to them???
    just got to sort out what its done to the electrics..
    Nov 2006
    Oldham, Manchester, UK
    Sounds strange that all the injectors decided to curl up and die at the same time.
    Its also strange that they are drawing a total of 40 amps, I would expect this from a set of glow plugs but not injectors, I would have thought something like that would show on a diagnostic! I assume there is plenty of fuel in the car????
    Is this the opinion of a main dealer or the garage round the corner? If its the latter, I'd get a second opinion.
    Good luck with it, could you keep us posted with what progress you make with it, fault finding/diagnostics etc and also finally, when its fixed, the cure.
    Welcome to VWAF.
    Marc.
    '96 A4 1.8. For spares now
    '98 A4.........New headache
    cheers marc
    have updated the origonal thread
    let u know the outcome
    ian.
    Nov 2006
    Thanks for the update Ian.
    Good luck with it mate.
  5. result
    just 2 let you know, finaly got the car back onthe road. god knows wat's bin in the diesel.
    it's cost me both the pump in the tank and on the engine, new injectors, filter a good blow out of the fuel lines and diesel tank.
    it's good to be back!
    ian.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Not been using any red diesel or veg oil have you?
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    london/ UK
    On PD engines, ussually the tandem pump pickup (the one in the tank) gets blocked and such, no diesel passes to prime the main injectors. Its highly unusual that all 4 duses failed at the same time, ussually, any contamination stops in the filter. Glad to hear that you are back on track !
    Feb 2007
    might be a stupid suggestion, but glow plugs?
    it seems to be working fine now,
    sat in a darkened room trying to get over the bill.....
    Feb 2007
    what was the bill? what did u change on it ?
  1. Replies: 2
    Last Post: 10-01-2008, 02:18 PM
  2. Golf Mk3 Cabrio wont start!!
    By Vassy in forum Golf MK3 - 1993 - 1999
    Last Post: 04-12-2007, 10:24 PM
  3. 1998 GOLF GL wont START.. PLS HELP
    By slykest in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-04-2007, 12:14 AM
  4. 1998 tdi golf wont start
    By a1alan in forum New Member Introductions
    Last Post: 11-04-2007, 10:57 PM
  5. **Help**2000 TDI GOLF WONT TURNOVER
    By bizzle in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-02-2007, 04:49 PM
