Thread: HID conversion, who's done it??
Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
  1. Re: HID conversion, who's done it??
    #41
    Tiptree, Essex
    Quote Originally Posted by a4suction View Post
    .............. Had some LED things the other day from a coupole of different suppliers but all they did when fitting was flash on and off, so they're posted back for a refund obviously. Just want sides that are white not yellow. ............... Suggestions????
    Check out this previous thread for compatible LED 501's......
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=53348
    A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
  2. Re: HID conversion, who's done it??
    #42
    Nov 2016
    I've got A4 b7 & put HIDs & ballasts in the headlights, (£40 each set)as I am really happy with the colour the projection(white with a tinge of blue) I have bought a set for my main beam.....These are in units that are not designed for HIDs.....as a result the main beam-I'm not too happy with as they project a circular shape and doesn't seem to project a light that 'floods' the area, not like I was expecting.
    Do you know from this description whether this is what I'm expected to get or would you from your experiences say that I've not positioned the bulbs correctly. I have as far as I can tell sat the bulbs with the return bar to the bottom as the rear of the reflected lenses has a cut-away part for the bar to sit in.
    Can you help shed some light on this? (No pun intended)!
    Regards
    Lockstock
  3. Re: HID conversion, who's done it??
    #43
    Sep 2016
    Ireland
    I had HID's in mine and swapped them out for LED's with the fan on the back, a lot simpler and much more tidy.
  1. lpg conversion
    By lone wolf in forum Chat - Anything with wheels
    Last Post: 26-04-2008, 09:10 PM
  2. vr6 conversion
    By xxx220 in forum The Commercial Range
    Last Post: 10-03-2008, 01:49 AM
  3. a4 LPG conversion ?????
    By 00carberry00 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-03-2008, 10:00 PM
  4. HID conversion
    By V5_170Mk4driver in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2007, 11:03 AM
  5. LPG conversion
    By new to vw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-06-2007, 06:26 PM
