Thread: Climatic just blowing HOT air with AC off
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Climatic just blowing HOT air with AC off
    Just joined the forum as I rcently got a 3 year old Polo (1.4 16v).
    Has a developed an intermittent fault -- blows hot air when temp dial is on coldest setting . AC is Off. turning temp dial does not change anything. Restarting the car sometimes clears the fault. Turning A/C on does not cool either. It has been re-gased recently. Sometimes with the A/C ON, turning the fan speed to full speed quickly start to cool the car -- but only sometimes.
    Is this a know problem with Polo's ?
    Any suggestions ?
    Nope. I guess I have joined the wrong forum.
    Tyldesley, Manchester, UK
    Welcome, sorry you never got any suggestions. It might be that this is something that has not occurred on a Polo before on this forum.
    You may also try posting in the Polo section
    One German, Two Italian.
    Thx MalcQV. I searched the Polo section and did not see anything similar. I guess I can move this.
  5. climatic blowing hot air
    hi my name is RAMA,dont know if I am doing this right,but i am trying 2 help vwpolo with heating problem sugest that you change your heater valve polo
    Quote Originally Posted by vwpolo View Post
    welcome to the forum, as has been suggested by malc, try posting the thread IN the polo forum, not just searching and you may receive more replies, this area of the forum tends to get a little neglected as people tend to specialise in a particular vehicle, hence they normally stay in the relevant forum area.
    i would suggest though, you may not receive a reply straight away and encouragment is always given to become an active member, not simply posting when you have a problem.....
    consequently i have read on this forum that a valve becomes blocked, which stops the air flow from funcitoning properly, you might want to search in passat and golf posts as well....
    good luck in addressing the fault
    Quote Originally Posted by RAMA View Post
    Thanks RAMA for the tip. Just got to find out how do do it now
    [quote=eshrules;17668]welcome to the forum, as has been suggested by malc, try posting the thread IN the polo forum, not just searching and you may receive more replies, this area of the forum tends to get a little neglected as people tend to specialise in a particular vehicle, hence they normally stay in the relevant forum area.
    /quote]
    Thanks eshrules. Sorry for the dumb question, but how do I move this thread ? or should I just start again ?
    [quote=vwpolo;17872]
    Quote Originally Posted by eshrules View Post
    /quote]
    You can't actually move it only a mod can. He means re-post it in the Polo section
    Canada
    I'll move it for you.
    Rob
  1. I have a problem with my VW Polo Climatic Control system, can you help?
    By apache24uk in forum Polo - Derby - Lupo - Fox
    Last Post: 28-11-2010, 02:42 PM
  2. blowing fuses
    By majick in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-06-2007, 12:24 PM
  3. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
  4. 2006 Climatic Problems - Blows Cold, but cabin hot?
    By longboyad in forum Passat - Archive Topics
    Last Post: 17-07-2006, 08:51 PM
  5. climatic control problem
    By Rupz911 in forum Passat - Archive Topics
    Last Post: 18-06-2006, 06:43 PM
