Thread: Sharan water leak
Results 1 to 10 of 11
  1. Sharan water leak
    Jul 2008
    HELP... I own and my wife drives a 2005 Alhambra tdi Stylance, I sold my last Sharan and bought this. I noticed about 2 weeks ago that the car was leaking water into the drivers side footwell. I removed the wipers and the plastic panel and the "scuttle drain hole" on the offside seemed clear when I poured water down it. Has anybody got any ideas.
    I also have a problem with the rear washer jet. The pipe to this has come off inside the rear door, does anybody know how to remove the rear tailgate trim panel.
  2. Re: Sharan water leak
    Jul 2006
    scunthorpe
    had this problem on my sharan, you have answered your own question re water in footwell, remove the kick panel on the passenger side under the dashboard adjacent to the A pillar, remove the trim that runs along the cill inner, under this trim you will find a wiring loom in the middle of the loom is the rear washer pipe!! (yes in with a wiring loom) follow this loom up towards the front of the car, where it dissapears into the bulkhead, there should be a join in the washer pipe, this usually where it comes apart allowing contents of washer bottle to empty into car when you operate rear washer
  3. Re: Sharan water leak
    Jul 2008
    Thanks for that but the water is on the drivers side not the passenger side and yes the rear washer pipe has come off but its off inside the rear tailgate and when this is used it fills the tailgate with water
    Thanks again, max5765
  4. Re: Sharan water leak
    Hi i have experianced water leaks from the side (triangle) windows,you can not see this, unless you remove the trim
  5. Re: Sharan water leak
    Jul 2008
    I've just stripped out all the trim around the little side window on the off chance and poured at least 7 watering cans of water around the top corner of the windscreen and not a drop came in. I managed to lift the carpets and they were sodden wet through. I've checked the drain holes in the scuttle panel on either side and these are clear and running freely into the wheelarch areas. I know this was a problem on the MK1 versions. I am now at a complete loss....
    THanks, max5765
  6. Re: Sharan water leak
    Sep 2007
    Peterborough
    I was getting water into the passenger footwell and trawled tinternet to find that most people reckoned the water was coming in through the pollen filter. Checked all this but to no avil.
    What I did find though was that there is a piece of trim on the outside in the bottom corner of the window (Wiper goes through it on the passenger side) that fixes by two plastic clips straight into the pillar. The car has had the problem before i bought it and low and behold there was a load of old silicone sealer around these clips.
    I tried pouring some water down these holes and straight away it went into the chasis leg and up into the footwell. Dont know if it could be the same on the drivers side???
  7. Re: Sharan water leak
    Jul 2008
    I know the trim panel you are refering to. It does clip to 2 plastic clips but these seem to be clipped to the bottom of the windscreen. I'll have another look tomorrow. "MATMCN" Was yours a MK1 or MK2 Sharan as mine is a MK2 and this trim could be fitted differently.
  8. Re: Sharan water leak
    Sep 2007
    Peterborough
    didn't know there was two versions. Mines a 96P so i'm guessing its a Mk1
  9. Re: Sharan water leak
    I've had the same problems with water leaks into my passenger footwell over the last 8 - 10 months. I thought it may have been the drain holes blocked, cleaned them still water getting in. Then windscreen cracked when the car was parked up over night. Hoping that this might be the problem I wasn't too disapointed, new windscreen, still water leaks. As a total stab in the dark I took the plastic arch from inside the inner wing in case that was blocking water flow. One month on no water leaks, car dried out. I dont't know what I've done but it seems to have done the trick.
  10. Re: Sharan water leak
    Jul 2008
    Thanks for that Peter J. I'll give that a try. Thanks Max 5765
  1. Help! Water Leak
    By VW_Pal in forum Golf MK3 - 1993 - 1999
    Last Post: 30-04-2008, 10:43 PM
  2. water leak
    By mark740_5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 11:37 PM
  3. A4 TDi Water leak
    By niffy53 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-10-2007, 08:41 PM
  4. A4 TDi Water leak
    Last Post: 04-10-2007, 03:26 PM
  5. Sharan TDi water leak.
    By bxbxbx in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2006, 01:43 PM
