Thread: Timing Belt Tensioner Help!!
  1. Timing Belt Tensioner Help!!
    I have a 1.9 TDI which I am changing the cam belt on. The problem I have is that in Elsa win it shows a different tensioner to the one I have.
    My tensioner sits on an eccentric plate which has a lug that fits into a recess in the rear housing to fix it in place. You then tension it by inserting a hex key in the front and rotate clockwise . The rear plate has u in it and when you tension a pointer attached to the pulley moves over this. the tensioner I took off had the pointer about 5 mm to the left of the u.
    How do I tension this tensioner to the correct amount? Should it be over the u position?
    I can send some pics if required
    Please help a bit stuck!!
    Paul
  2. Re: Timing Belt Tensioner Help!!
    135 Post(s)
    2026 Post(s)
    Post some pics of old and new plus part numbers and your engine number/year.
  3. Re: Timing Belt Tensioner Help!!
    Picture 1 is from Elsa Win for my car.
    My tensioner is different - see picture 2 which is it fitted to the car in approx the same position as the old one.
    My chassis no is WAUZZZ4B53N114092 - THE ENGINE CODE IS AVF 130PD. Couldn’t find the number!
    The part no of the tensioner is : 038-109-243-M
  4. Re: Timing Belt Tensioner Help!!
    Sorry just to confirm both the old and new tensioners are the same as per pic 2. I just need to know how to set it up correctly.
  5. Re: Timing Belt Tensioner Help!!
    135 Post(s)
    2026 Post(s)
    Remove the Elsa pic please, it is not allowed to use copy write protected material on here and you will get your wrists slapped. The tensioner you show in the diagram is the earlier hydraulic type and you can’t just swap from that to the friction type. Did your car have the hydraulic tensioner before? It shouldn’t have.
  6. Re: Timing Belt Tensioner Help!!
    My car has the friction type in pic 2. I am not changing types. All I need to know is how to set up a friction type tensioner.
  7. Re: Timing Belt Tensioner Help!!
    135 Post(s)
    2026 Post(s)
    Obviously your copy of you know what is too old to contain info on the friction type. PM me your email.
  1. Please help! TDI Timing belt tensioner...
    By Kraig in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2008, 06:25 PM
  2. Setting Timing Belt Tensioner - 1.9 TDI AWX
    By daveo138 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-01-2008, 09:58 PM
  3. Timing belt stripped,tensioner broke, Cam question, Please Help
    By tchrgrl in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2007, 03:09 AM
  4. Timing belt tensioner problem
    By gbrownlee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:43 PM
  5. Timing chain tensioner
    By NIgolf in forum Passat - Archive Topics
    Last Post: 20-03-2007, 07:10 AM
