Thread: ECU location? water? engine wont start
Results 1 to 8 of 8
  1. ECU location? water? engine wont start
    Hi, Could someone tell me where the ecu is located on the MK3?
    My petrol 1.4 stopped on me after driving through a deep puddle and wont start, it has fuel and a spark at the leads, I've checked the pressure regulator and every connection I can find under the bonnet and all the relays but think it's maybe water on the ecu connection, if I can find it!!!!!
    This happened before in torrential rain and I fitted a new fuel pump and filter which seemed to cure it but I now think that water on the ecu might have been the cause and dried out while I was waiting for the pump.
    Help please
  2. Re: ECU location? water? engine wont start
    Jun 2008
    isnt the ecu unit thing under the rear seats on the inside of the car? in my mk3 theres something there anyway! looks like an old radio unit
    maybe u got water in the other bits n bobs like the air filter or the force of the water pulled a sensor out of place?
  3. Re: ECU location? water? engine wont start
    132 Post(s)
    1979 Post(s)
    The ECU is under the windscreen in the plenum chamber and they don’t get wet. If you have fuel and spark it should run so how about the possibility that it pulled water into the engine and hydraulic locked? What about getting a fault code read done?
    Adam, the ECU under your back seat means that you have a pre 95 car with ABS or an automatic.
  4. Re: ECU location? water? engine wont start
    Hi Crasher,
    The engine turns over OK I have a spark and the plugs are dry which makes me think it's water in the ecu playing games with the single point injector, plus my cover doesn't fit that well of the said plenum chamber.
    Short of taking the carb/injector cover off and seeing if it will try to run on some cold start squirted in there I'm thinking it's the ecu???...
    ... but I'm open to suggestion, I did have an ignition coil fail but that was a couple of years ago and then it would start but not drive off.
  5. Re: ECU location? water? engine wont start
    132 Post(s)
    1979 Post(s)
    If it was water in the ECU you would not get a spark. What about a fault code read? Can you hear the fuel pump running? The most common failure is the distributor hall sender but you say you have a spark.
  6. Re: ECU location? water? engine wont start
    Jun 2008
    ah your spot on mate, automatic all the way
    carry on!
  7. Re: ECU location? water? engine wont start
    132 Post(s)
    1979 Post(s)
    That's the box ECU.
  8. Problem solved!
    The problem seems to have been water on the ecu contacts as I had the ecu out, disconnected it and sprayed the connector with an electrical contact cleaner and it started!!!
    The rubber edge has perished on the cover over this area (VW want a fortune for one of these covers) and I think it had let water in, plus the loom was also sloping downhill towards the connector so any water falling on the loom would run towards the connector so I have altered it's route to provide a drip loop and put a bead of silicone sealer on the edge of cover for now.
    Very happy at solving this one.
  1. Non starter, engine turns alright but wont start A4 1998 1.6 petrol
    By kobby in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 10:16 PM
  2. Randomly wont start, not turning engine over.
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 09:36 PM
  3. Engine Cuts out / Wont Start
    By james_101 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2007, 10:16 AM
  4. vento engine wont start
    By norton in forum Vento - 1994 - 1998
    Last Post: 25-07-2007, 10:23 PM
  5. Washed engine, now wont start
    By abc123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-07-2007, 04:27 PM
