Thread: AUDI A6 2.5tdi ignition problem
  1. AUDI A6 2.5tdi ignition problem
    Hi there ... Could anyone advise what can cause an ignition problem? I just bought an A6 2.5tdi 2000 model, and there is a major problem with its ignition. The symptomes are the following... in the mornings it starts well, with almost no problem. But once you leave it OFF for 3-4 hours afterwards its starts very difficult, sometimes it takes up to a minute to start the car. I changed all the 6 spirals which heat the diesel, but still it does not help it. ANybody came across with this problem?
    Unfortunately the location of the car is such that there are no Audi service centres, and the private ones cannot understand the problem.
    Thanksss
    Oct 2005
    Lutterworth
    Well it could be associated with the coolant temperature sender.
    Cheap and easy to replace.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Thanks buddy......will try that one as well
  1. A4 2.5Tdi Power problem, not AFM??
    By Audiboy in forum Archive posts
    Last Post: 08-02-2008, 10:23 PM
  2. A3 Ignition Coil Pack problem
    By walanis in forum Audi A3 - Archive Topics
    Last Post: 22-05-2007, 02:42 PM
  3. Stereo ignition sense problem
    By andym82 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 11:50 AM
  4. ignition problem?, 1.9 tdi polo
    By polonewb in forum Polo - Derby - Lupo - Fox
    Last Post: 25-04-2007, 06:04 PM
  5. possible ignition problem Vento
    By Brucie in forum Vento - 1994 - 1998
    Last Post: 02-02-2006, 11:13 PM
