Thread: Chiptuning
  1. Chiptuning
    Jul 2016
    Stoke on Trent
    New too the forum I have a 2008 estate 2.0tdi and have purchased a Drakebox, the wiring harness that has come with it has a three pin plug, can anyone direct me too the plug it needs be connected too?
    Elliot
  2. Re: Chiptuning
    Dec 2010
    Worcs, UK
    Did it not come with instructions...?
    Three pin plug sounds to me like it may want to go to MAF or air temp sensor.... but who knows.
    Personally I would not fix such a crude 'box' to my car. Most likely it just fakes some signal and fools the ECU into injecting too much fuel.
  3. Re: Chiptuning
    May 2012
    Everywhere
    308 Post(s)
    Put it in the bin , check you won't join the 77mm club and get a remap .
  4. Re: Chiptuning
    SE London
    In other makes' forums it's spoken of as holding a ripped-off remap from someone else's proper remap. By proper remap mean your current ECU settings downloaded, sent for re-write, and uploaded to your car's ECU again (Superchips, etc.) Which is what the OP should get specific for his car and his engine (if TDi after EGR restrictor fitted).
    OP doesn't say what car this is unit is for. These are meant to be sold specifically for different makes, marques, engines within a marque
  5. Re: Chiptuning
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    It's for a 2008 TDI Estate as the OP mentioned but if it has a DPF then the 'tune' would be limited as the DPF will restrict exhaust flow. Using a Drake box on the higher settings may even cook the DPF which will get way too hot during regeneration.
    Sure way of killing off your engine way sooner than the inherent faults VW kindly build into these cars that will try to kill it anyway!!
    Mad Mitch
  6. Re: Chiptuning
    SE London
    OP doesn't say what car the Drake box is for. Says it came without destructions...
    Yes, OP did say his car was a 2008 TDI Estate
  1. Chiptuning
    By t0m541 in forum Archive posts
    Last Post: 02-04-2007, 10:25 PM
