Thread: tai
  1. tai
    Jul 2007
    Hi guys, first posting since joining a year ago! I've got a 53 plate passat Tdi 130 estate, and for some reason the driver's side tail lights and the front pilot are not working. Side, stop and fog all ok. Changed bulbs and fuses all seem in good order. Anyone got any immediate thoughts before VW charge me to book the car in!
  2. Re: tai
    Which fuse did you replace?
  3. Re: tai
    Jul 2007
    Only replaced the bulbs, as the relevant fuse tests good.
  4. Re: tai
    The right front side light and the rear right tail light have 2 things in common,the fuse 22 and the light switch.You need to see if you have 12v on the fuse 22,if you have no voltage on the fuse then you have a fault with the switch.
  5. Re: tai
    Jul 2007
    Ok, I'll get the meter out and put it across that. I'm certain it must be something obvious. Thanks, will give that a go and let you know what happens.
