Thread: Replacing a brake light bulb
  1. Replacing a brake light bulb
    Jun 2008
    Glasgow
    Hey Folks
    First time poster here.
    I picked up my 04 plate 1.9TDi 130 Avant last Monday and am loving. One small problem though. When I started it up this morning the computer told me that the right hand brake light is out.
    I have had a quick look on tinternet and it appears that replacing the bulb is reasonably straight forward, however, will replacing the bulb reset the warning on the dash or will that require a diagnostic plug in to be reset?
    Thanks for any help you can offer.
    Ian
  2. Re: Replacing a brake light bulb
    Jul 2007
    When you change the bulb the error will also clear. Bulbs are constantly fusing and it would certainly be a costly affair if each time you needed to have the error cleared professionally.
    Bishy
  3. Re: Replacing a brake light bulb
    Jun 2008
    Glasgow
    I thought that but the handbook helpfully tells me to take it into the *********** inorder to have a bulb replaced so I thought there must be more to it than just changing the bulb.
    Thanks for the help.
  4. Re: Replacing a brake light bulb
    Were I is Now
    Quote Originally Posted by sbuk73 View Post
    It would....but looks like that is just what's needed on the newer A6
    Just swapped a tail and a brake bulb....neither of which cleared the fault...in fact they did not even get power until the fault was cleared....not sure if this is the norm....hope not....but then I do have VCDS to reset them
    2010 S4 in exclusive classic red and every option under the sun...as well as my 80 cabriolet 2.6e auto fun day car...not forgetting a slightly Smashed but saved waiting for some repairs 01.5 B5 A4 2.4SE Tip - Votex body kit, Hidden Microwave PDC, Pirelli X-Pressure TPMS, Hardwired Bel RX65e, Lamp Guards...and the exclusive Red Logo Audi Sport Valve Stem Caps!
  5. Re: Replacing a brake light bulb
    Dec 2007
    Aberdeenshire, Scotland.
    If you follow this guide you will have no problems replacing your bulb.
    https://www.vwaudiforum.co.uk/forum/s...ead.php?t=7485
    I changed the brake light bulb on my 03 A4 Avant a while back using the guide, and the error clears when changed.
    Just take your time when removing the rear cluster.
  6. Re: Replacing a brake light bulb
    Mar 2008
    angus, scotlandshire
    Quote Originally Posted by Braveheart1981 View Post
    Hey Folks
    Ian
    hi ian,
    there is a how to guide at the top of the page on b6 section on changing lamps.i used it last week and found it a big help.i suggest you try it.i changed both my brake light bulbs in less than 10 mins......
    kip
    54 a4 avant tdi quattrosport.
  7. Re: Replacing a brake light bulb
    Jun 2008
    Glasgow
    Did it at lunch time today. 5 minute fumble in her rear end and she is all happy again. Cost a grand total of £1 for the bulb and the warning light went out.
    I still have a warning light on though. Seems to be telling me I am low on fuel. Does anyone know of a £1 fix for that problem. lol
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. a4 brake light bulb
    By mike d in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2008, 07:00 PM
  3. RS6 Brake Light Bulb Replacement
    By rief944t in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-07-2007, 08:37 AM
  4. brake light bulb!!!!
    By jjt5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2007, 11:09 PM
  5. Retrieving lost brake-light bulb
    By VWSmudge in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-03-2007, 10:32 AM
