Thread: coding, for cruise control
  1. coding, for cruise control
    Jun 2008
    chester
    hi fellas, can you help me? i have fitted the cruise control to my car what else do i have to do to get it to work? i'v been told, engin, login in, enter the cc code select do it ? is this right? if so its doing nothing, where am i going wrong? its an audi a4 1.9 tdi 52 plate.
    feel like pulling my hair out, well if i had some lol.
    thanks, lee
  2. Re: coding, for cruise control
    Bournemouth
    nickynibbles has posted a guide about his b6 cruise upgrade. his guide links to other places where the coding help can be found.
    http://audi-sport.net/vb/showthread....625#post505625
  3. Re: coding, for cruise control
    Angus, Scotland
    Lee,
    What SCSM module do you have fitted?
    If your module doesn't support cruise then it won't accept the coding.
    Also , remember when checking if the cruise is working you need to be above 30kph for the light to come on and if you check 01-Engine >> Measuring Blocks >> Group 006 you should see a bank of three zeros, if any of these are a 1 then you have either a faulty clutch switch or brake light switch. Both of these will stop Cruise working as the car thinks you have the clutch or brake pedal pressed.
    Hope that helps
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  1. Cruise Control
    By Stuart_B in forum Golf MK4 - 1999 - 2004
    Last Post: 20-10-2008, 10:58 PM
  2. Cruise control
    By RichardCranium in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-07-2008, 09:01 PM
  3. a4 cruise control
    By lee a4 in forum VCDS - General Questions
    Last Post: 22-06-2008, 09:29 PM
  4. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  5. Cruise Control add on to a 2.3 V5?
    By sdds_8 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-09-2007, 03:02 AM
