Thread: Removing instrument cluster plastic trim
  1. Removing instrument cluster plastic trim
    May 2008
    When I bought my B6 there was what looks like water spots behind the plastic trim in front of my instrument cluster. You can imagine how much that can annoy someone since that is where I am looking every time I drive the car. How do I remove the plastic trim? I was watching a video an how to install an RNS-E and they did it in like a second but did not show how. Thanks a lot for your help! Can't wait to clean it.
  2. Re: Removing instrument cluster plastic trim
    Dec 2007
    what do you want to remove the cover on the clocks or the cover holding them in
  3. Re: Removing instrument cluster plastic trim
    May 2008
    If I am not mistaken, there is a plastic trim piece in front of the instrument cluster, which also has a plastic cover. It looks as though the spots are on the trim piece that is in front of the cluster. So I dont want to take out the cluster, just the clear plastic piece in front of it. Does this make sense at all?
  4. Re: Removing instrument cluster plastic trim
    Dec 2007
    so u want to clean the clear cover over the clocks i take it u want to clean the inside of it ?
  5. Re: Removing instrument cluster plastic trim
    May 2008
    Right, I dont know how, but the previous owner managed to get spots on the inside of the plastic trim. I need to take it out to clean the inside of it.
  6. Re: Removing instrument cluster plastic trim
    Jan 2008
    Lancashire
    I'd like to know how to do this too as mine has a lot of dust inside that I want to get rid of.
    54 Audi A4 Avant 1.9TDi 130 SE 6-speed, RNS-E, rear parking sensors, bluetooth
  7. Re: Removing instrument cluster plastic trim
    Jan 2008
    Angus, Scotland
    If you pull the plastic panel inbetween the clocks and the steering wheel it should come off to reveal two Torx screws which are holding your instrument cluster in place.
    Undo these two screws, then remove the fuse panel cover on the right hand side.
    Reach in through the gap and push at the back of the instrument cluster to remove it.
    There are two multi-plugs one one either side to remove then you will have the instrument cluster in your hands.
    IIRC the pastic outer cover is held in with clips, remove these and you can clean to your hearts content.
    Then reverse the above to put them back!!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  1. Tips needed on cleaning up plastic trim
    By chalkie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2008, 09:00 PM
  2. Removing the instrument cluster
    By marshy26 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2008, 06:25 PM
  3. Removing plastic trim on sill of the door
    By sheka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 08:47 AM
  4. Removing Instrument Cluster On 2002 Golf V5 To Remove Emissions Warning Light Bulb
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-06-2007, 06:02 PM
  5. golf mk 3 exterior black plastic trim
    By mrfunk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-08-2006, 08:16 PM
