Thread: Intermitant Starting problem
  1. Question Intermitant Starting problem
    Jul 2008
    Hi all can anyone help, I have a intermitant starting problem with my mk3 Golf GTI 2.0 8V. Sometimes I turn the key and nothing not one sound turn again nothing. Normally after a few minutes the car fires and starts.
    Any ideas
    thanks John
  2. Re: Intermitant Starting problem
    Quote Originally Posted by jrodd View Post
    Any ideas
    thanks John
    more than likely the starter motor on its' way out,but may be the relay,or a loose battery lead/bad earth.
    if you have a bad connection/earth, your clock on the dash would go to 000000 when starting and would need resetting everytime.
    if you can get at the starter motor,try tapping it with a hammer or such if it doesn't turn.have someone on the key,if it doesn't turn,but turns when knocked with the hammer,you need a starter,(assuming of course all normal ignition lights are on).
    stewy.
    4th cog,--two to go
  3. Re: Intermitant Starting problem
    Southampton, UK.
    Had a similar issue on my Mk3 - when turning the key all the way and hold it there (as you do to start the engine) there would be nothing for a second or two, then it would start. Turned out to be a dying battery - after it was replaced, after completely dying at a level crossing in the pi$$ing rain, it starts like a dream!
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  4. Re: Intermitant Starting problem
    Jul 2008
    thanks will give it a try......
  5. Re: Intermitant Starting problem
    Oct 2007
    Hi There is the possibility,it could be the electrical part of your ignition switch.
  1. Intermitant Boost Fault (Code 17965)
    By dazrick68 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2009, 08:51 PM
  2. intermitant door swtich
    By mungochris in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-06-2008, 08:23 AM
  3. Please Help Intermitant AC Fault
    By robinwells in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-05-2008, 09:27 PM
  4. Hot starting intermitant problem
    By beetlesilver in forum Beetle 2000-
    Last Post: 22-04-2008, 01:28 PM
  5. intermitant loss of brakes 1.9 TDI soprt
    By bobj102 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 11:47 AM
